Photos - MAC Install - Expected better fit
Old Jul 17, 2005 | 12:39 PM
JGA's Avatar
JGA
Default Photos - MAC Install - Expected better fit
Hi
Just woundering if anyone else is using a set of MAC headers and catalytic Y pipe. I did not expect to loose so much clearance on the drivers side. Also, I had to shim down the tunnel brace to fit at the rear. Anyone else using the cat Y pipe experienced this type of fit?
Thanks JA
Attached Thumbnails Photos - MAC Install - Expected better fit-picture1.gif   Photos - MAC Install - Expected better fit-dscn0835.gif
Old Jul 17, 2005 | 12:56 PM
Tally TransAm's Avatar
my mac orp hung down pretty far
i dont believe in cats
Old Jul 17, 2005 | 03:16 PM
mikemodano9c's Avatar
everyone says the mac cats suck...but i don't believe in cats either
Old Jul 17, 2005 | 04:07 PM
JGA's Avatar
JGA
Hi
I am happy with the performance. The system really woke up my car. I have no dyno results, but it feels like I got lots of HP and torque. So I assume they do not flow too badly. I was planning on lowering my car, but with this exhaust, I assume the cat will get beat up pretty quickly.
Thanks JA
Old Jul 17, 2005 | 08:33 PM
SSBRONCS's Avatar
i'm happy with my macs but also don't believe in cats
Old Jul 17, 2005 | 11:35 PM
JGA's Avatar
JGA
Hi
Anyone with the same fit issues? Just woundering if my pipe is out of spec.
JA
Old Jul 18, 2005 | 12:42 AM
Full-Force's Avatar
I keep telling people over and over that it doesnt matter what kind of header you get. Nearly all of the longtubes I have put on tuck so tight to the car on the driver side that it is nearly touching the floor of the car. How can you get better clearance than that? Sure if you are only running a 2.5' pipe coming off of a set of mids or shorties you will gain 1/2" but thats it.
Example. Take a set of pacesetter, hooker, jet hot, or flowtechs, and try and run a 3" pipe straight off the header and its gonna be sandwiched against the floor. Thats why people have a fit with their y pipes.
Old Jul 18, 2005 | 07:04 PM
JGA's Avatar
JGA
Hi Full Force
I agree with you opinion. It took me a while to get under there and have a full look at the clearance. There realy is not much room. Also there is a cross brace a little behind the cat that makes it impossible to move thing around. However, I think on my system I can get that cat up about 1/4" with a bit of custom fitting. It may mean modifying the front pipe a little, but I think I will go for it. Every little bit of clearance will help.
Thanks JA
Old Jul 19, 2005 | 06:16 AM
Frosty's Avatar
Not sure why people say they suck. Mine when it very easily. NO clearance issues. The y-pipe fit in nicely. The only issue(if you want to even call it that) was the passenger side collector was pretty damn close to the heatshield we have there...a little :cough: modifying :cough: to the heat shield and bam, it fit just fine.
The MAC ypipe tucks in better than the stock ypipe did
Old Jul 19, 2005 | 07:19 PM
JGA's Avatar
JGA
Default Frosty
Hi
Was you system catalytic or ORY? The ORY is actually a different part and fit.
Thanks JA
Old Jul 19, 2005 | 08:12 PM
Frosty's Avatar
ORY
I know it's different.
Old Jul 19, 2005 | 08:39 PM
JGA's Avatar
JGA
Thanks
The info helps.
JA
