installing pacesetters and tsp ory 2day.....
Old Jul 22, 2005 | 12:35 PM
GreekGator's Avatar
Default installing pacesetters and tsp ory 2day.....
ok guys, 2days the day. wish me luck. i will post after finished and tell how it went and problems that i may encounter.
Old Jul 22, 2005 | 01:31 PM
LS1PoweredZ28's Avatar
I didn't have any trouble installing my pacesetter LTs, they fit like a glove. The pacesetter y-pipe on the other hand was a pain, hopefully the TSP y-pipe will be better. The only modification I had to do was to cut off a bit of the block tab, but that was really easy. Just have fun and take your time.
Good luck,
Kevin
Oh yea, see you when you come to Gainesville!
Old Jul 22, 2005 | 01:55 PM
~JOSHUA's Avatar
Good luck...
Old Jul 22, 2005 | 02:31 PM
josh99ta's Avatar
Sold The Fun Stuff :(
Today. It's "today." If you can't spell that correctly or take the time to spell it correctly I worry about your ability to install headers.
Good luck.
Old Jul 22, 2005 | 02:32 PM
stangkiller's Avatar
Good luck.
maybe he just wanted to spell it quickly. your joking right?
Old Jul 22, 2005 | 04:00 PM
GreekGator's Avatar
sorry, didnt know we have english professors here. i know how to spell today *******.
Old Jul 22, 2005 | 04:31 PM
LC's Avatar
LC
kinda off topic but i am going to start my LT install this monday, and i still dont take the chance to buy a torque wrench.. Should I buy it or i can make it without it?
Old Jul 22, 2005 | 05:14 PM
I didn't use one on my install, thats not to say I wouldn't recomend one. Its almost impossible to get a torque wrench on some of those header bolts anyways.
Kevin
Old Jul 22, 2005 | 05:39 PM
FBDYLVR's Avatar
Get the car up as HIGH as you can.
Old Jul 22, 2005 | 06:01 PM
APeteSS's Avatar
Don't worry about it. If you use lock washers on your bolts, I'd just tighen them so they're all compressed flat. Then listen for leaks.
Old Jul 22, 2005 | 06:05 PM
GreekGator's Avatar
guys,im having trouble loosening some of the header bolts....any recomendations?
Old Jul 22, 2005 | 06:06 PM
taintedmeat's Avatar
WD40 and a breaker bar
Old Jul 22, 2005 | 06:23 PM
WD40 or some other kind of penetrating lube, sometimes you have to let it sit for a little while.
Kevin
Old Jul 22, 2005 | 07:09 PM
skywalkrNCSU's Avatar
SSU, come over and relax
haha good luck with that pos tsp ory
that piece of junk gave us so much trouble. just remember to use PLENTY or lube on those parts so you can move em around
Old Jul 22, 2005 | 07:31 PM
GreekGator's Avatar
thanks everyone for all the help so far!
Old Jul 23, 2005 | 12:13 AM
exstanger's Avatar
I just did mine the other day and didn't have any trouble with the install at all. It was the removal that was a pain. I finally took a 1/2 air gun set it to tighten and just broke the bolts off on the old y pipe to the convertors. Mine were so rusted they didn't even have thread left. As far as the bolts that hold the manifolds on I used a 3/8 air ratchet. Best tool I ever had. Oh I almost forgot I had to go back and loosen my header bolts and cat back to get the y-pipe on. One last thing (I'm not tring to sound stupid here) when you go to install the headers make sure the gaskets are on right. If you use the stock ones they will say manifold side and bottem. Four of the bolts will go in great but the middle two will not.
Old Jul 23, 2005 | 12:39 AM
00 Trans Ram's Avatar
You said it! Just stick the air ratchet in there and press a button. I can't imagine trying to turn a ratchet in there!!
