header install question?!?!?!?
Old Jul 28, 2005 | 07:05 PM
ChaseSS's Avatar
Default header install question?!?!?!?
HOW DO YOU GET THE DIPSTICK OUT???
okay got the drivers side header in (jet hot LT's) and now I can't even get the stock exhaust manifold off!!! What did you guys use to get it off because I can't fit a socket wrench on 3 of the 6 bolts!! any links to an install page would be wonderful as well...... anything else I have to take out on the passenger side?
Old Jul 28, 2005 | 07:07 PM
LS1ownzYOU's Avatar
On mine we removed the EGR (put it on after), the whole girdle of coil packs, the dipstick, and moved around some other ****.
Get the car up AS HIGH AS POSSIBLE, makes things alot easier
Old Jul 28, 2005 | 08:31 PM
ChaseSS's Avatar
yeah I've got the car as high as it can go.....with removing the dipstick, I already removed the bolt on the bracket that holds the dipstick on right next to the exhaust the manifold, do I just yank on it now or what? is there a bolt where the dipstick goes into the block or what?? help??
Old Jul 28, 2005 | 08:58 PM
HavATampa's Avatar
Yank it. The only thing holding it in the block now is a small rubber o-ring. Quit being a panzy!
Old Jul 28, 2005 | 09:00 PM
Lithium's Avatar
SSU's Drunk Typing Whore
. Once that bolt is removed just pull it out. Putting it back in though is a different story. A friend will come in handy .
Old Jul 28, 2005 | 09:01 PM
LS1ownzYOU's Avatar
YANK IT YANK IT YANK IT
HAHAHAHAHAHAHAHAH
Old Jul 28, 2005 | 09:04 PM
HavATampa's Avatar
This is the only link on header installs I could find without using the dreaded search feature of this board. Just kidding about the above pansy remark. Take your time and don't force anything, you'll figure it out.
http://www.ls1camaro.net/sections.ph...ticle&artid=57
Old Jul 28, 2005 | 09:07 PM
HOSS's Avatar
yea, pull off the egr and air ****, there are either one or 2 bolts for the dipstick, remove the coil packs, be sure to spray the header bolts with penetrating oil and let them sit, i let mine go over night, get the car as high as u can, and get er done
Old Jul 28, 2005 | 09:11 PM
HavATampa's Avatar
And by all means, disconnect the freaking battery. I can't believe the amount of people that fail to do that and short something out and come on here and cry about it.
Old Jul 28, 2005 | 09:51 PM
ChaseSS's Avatar
alright!! thanks a ton guys........ I must go now......and finish the mess I started
Old Jul 29, 2005 | 12:55 AM
ChaseSS's Avatar
the deed is done, the headers on are on!!!!!!!!!!
Old Jul 29, 2005 | 02:21 AM
JustAnIlluzion's Avatar
nice!~
Old Jul 29, 2005 | 03:02 AM
hawaiiboysz's Avatar
Let me tell ya something funny. After I installed my headers on my Z I was soo stoked that I forgot to reinstall the dip stick. took it on a drive and seen a puff of smoke everytime I floored it took it home took a look and I could not figure it out grab my smokes on my tool box and grabed the dip stick instead. That there is the stupidest thing that I have ever done. lol
