which band clamps to get? (pics)
Old Aug 6, 2005 | 06:58 PM
JustAnIlluzion's Avatar
Default which band clamps to get? (pics)
i have some pacesetters (3in collectors) and will be getting some true duals. i think we're going to do 3in duals into a 3in xpipe then dumped b4 the axle. which band clamps would work best? i imagine we're going to flare the 3in duals to slip over the header collectors.
one is from jegs, other is from summit
Old Aug 6, 2005 | 07:09 PM
Sudz's Avatar
both those clamps are pretty much the same, except the first pic is just showing how it contours to the pipe after time once you tighten them down. , you can get those at napa.
Old Aug 6, 2005 | 07:11 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Go with the top one. I got some just like that from jegs. They were really nice and worth the money.
Old Aug 7, 2005 | 12:45 AM
Time2Kill's Avatar
MASS seller approved
I've used both and I prefer the bottom ones. I've had a few cases where the tops one didnt seal to the larger diameter pipe because the clamp is already 'expanded' to fit over the larger pipe.
The bottom ones have always fit excellent and seem to give a tighter seal.
Old Aug 7, 2005 | 02:44 AM
SIK02SS's Avatar
i agree with going with the bottom one, used it and works great...i believe $12 at napa (NOT pep boys/kragen/auto zone)
Old Aug 7, 2005 | 02:50 AM
SiL3NtXWS6's Avatar
Go with the bottom, it will conform when you tighten it.
Old Aug 7, 2005 | 06:32 AM
Dustin's Avatar
i have 2 sets of the bottoms and they fit great
Old Aug 7, 2005 | 08:42 AM
HavATampa's Avatar
The top pic isn't the same as the bottom one. It's made with the step design before it's put on. I agree with the others, it doesn't seem to fit as tight due to the pre-formed design. Buy the flat one.
Old Aug 7, 2005 | 03:15 PM
thanks for the replies, il go with the bottom ones. il call napa and see if they have em in stock, otherwise il get them from the jegs store on ebay.
Old Aug 7, 2005 | 09:02 PM
TJ's Avatar
TJ
i vote for the bottom one in all situations except where it dont work.
i actually couldnt get one to seal on my custom y pipe, and the jegs (formed) clamp worked great.
good luck with either, you cant go wrong.
Old Aug 7, 2005 | 10:20 PM
-IH8RICE-'s Avatar
Napa can get them next day if they dont have them in stock. I just swapped all mine over and they were one short. They had it by 2 the next day.
Old Aug 7, 2005 | 10:34 PM
Full-Force's Avatar
Well I have used the flat ones and dont like them because the expanded part of the pipe holds the band off of the smaller part of the pipe.
I have some of the top ones on order. I will try and post back to tell everyone how they work. If they dont work any better than the flat oones then I will be welding me a 3 bolt flange in place of the slip fit joints.
Old Aug 7, 2005 | 11:10 PM
LawmanSS's Avatar
My Kooks ORY came with the top design...FWIW, I've had no problems.
Old Aug 7, 2005 | 11:17 PM
OldeSkool's Avatar
Get both!
Old Aug 8, 2005 | 08:16 AM
redmist's Avatar
Top one. Works fantastic, look great , no leaks. The bottom one is only if you butt two pipes together. If you get the right size the top on "conforms" as it should when you tighten the clamp.
Old Aug 8, 2005 | 12:40 PM
rush7's Avatar
got mine at napa...worth it here as well.
Old Aug 8, 2005 | 01:18 PM
777's Avatar
777
I think either one would work. Personally I'd go with the bottom. You should be able to get a better seal with the bottom one.
Old Aug 8, 2005 | 02:35 PM
shawn's SS's Avatar
Which ever one you get, TIGHTEN the living **** out of it. I use an air impact gun
Old Aug 8, 2005 | 08:24 PM
DaddySS's Avatar
The bottom ones are the walker heavy duties, I think they're the best and you don't need to hold the other side with a second wrench.
Old Aug 8, 2005 | 09:59 PM
TJ's Avatar
TJ
you are correct sir.
the NAPA ones WILL require 2 wrenches.
