exhaust pop/backfire ??
Old Aug 23, 2005 | 09:49 PM
BLCKBRD's Avatar
Default exhaust pop/backfire ??
When my engine is cold or not up to full temp yet, and I let off the gas or shift gears, I hear this poping noise or backfire. I did some searching, and some people say it's normal but others say it's not. I just changed my plugs and wires, and I still don't get as good of gas mileage.
Could it be my o2 sensors? Or something called the check valves, what exactly are the check valves and how do you replace them?
Old Aug 23, 2005 | 10:03 PM
TAQuickness's Avatar
there are several current threads about this. you don't even need to search, just scroll down.
FYI - it's unburned fuel lighting off in the pipes aka RAZ
Old Aug 23, 2005 | 11:17 PM
JEB Garner's Avatar
I have found that the backfiring is normal on a cold engine. I think all Camaros do that when the engine is cold. I assure you that it will not hurt a thing. In fact, I would worry if it did not backfire then the engine is cold.
Old Aug 24, 2005 | 04:50 PM
BLCKBRD's Avatar
anyone else have insight on this? Does anyone know anything about these check valves on the AIR system?
Old Aug 24, 2005 | 05:07 PM
Uno99's Avatar
Check for a cracked spark plug. I crack one and my car popped amd backfired.
Old Aug 24, 2005 | 06:03 PM
Silver02TA's Avatar
yup, they all do it man
Old Aug 24, 2005 | 06:26 PM
Grimes's Avatar
My car does this when cold - In fact I let out the clutch fast sometimes just to hear it pop, lol. 40k miles later, still does it, and no problems It's normal!
Old Aug 24, 2005 | 06:29 PM
yak's Avatar
yak
mine does it when it is warm to, when the cutout is open and I drop the tranny to 2nd from 50mph (A4) I get a few pops. I wouldn't worry about it.
Old Aug 24, 2005 | 06:36 PM
spy2520's Avatar
i hear it all the time, especially with the cutout. I can actually make it do it at a certain rpm if i let off then feather the throttle. I always thought it was pretty cool.
Old Aug 24, 2005 | 07:11 PM
freakynipples69's Avatar
3k and above I can make it happend. I think it's very cool, a big head turner
Old Aug 24, 2005 | 08:31 PM
BLCKBRD's Avatar
ok, thanks. I guess I won't worry about it then.
Old Aug 24, 2005 | 08:56 PM
Tranzaman00's Avatar
Drove me crazy for years cool at first then it gets embarrasing cause it makes the car sound like a hunk of ****, like somethings wrong with it. removed the air system due to the faulty check valves now I can't make it do it if I tried.
Old Aug 24, 2005 | 09:08 PM
RedWS601's Avatar
yup same here when I start it up. Sounds cool though!
Old Aug 24, 2005 | 09:51 PM
wildz's Avatar
Talking
Same here, i have the loudmouth exhaust and auto trans. When i leave it in second and decelerate from about 45mph, if i feather the gas i can make it pop all the way down. I also think it sounds kind of cool.
