Spark Plug Install!!!
Old Sep 6, 2005 | 07:51 PM
02 SS's Avatar
Default Spark Plug Install!!!
I own an 02 SS. Today I installed the tr 55's. I have 41K on the car so I kept the factory wires. My only mods are slp loudmouth and a lid. After the install everything seemed fine, but now under a load and at full throttle it misses. I get a flashing SES light. I gapped the plugs at .055.
Even though the wires look fine, could I have damaged them while removing them. They were difficult to get off and I had to pull very hard on the wire instead of the boot. Has anyone heard of something like this? Do I need to go ahead and order new wires? Any help would be appreciated.
Old Sep 6, 2005 | 08:02 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
99% of the time when you have a flashing SES, it's either a loose plug wire, or a very bad one. I would check that each wire is snapped in good on each coil and plug. My experience is another 90% of the time it's the #8.
Luck,
Gerald
Old Sep 6, 2005 | 08:09 PM
NviouSS's Avatar
check to make sure all your plug wires are on tight. you should hear them click twice.
Old Sep 6, 2005 | 08:11 PM
2000Hawk's Avatar
they are a bitch to get on especially number 8, but if the plugs are not fully on, your SES will start to flash.
Old Sep 6, 2005 | 10:36 PM
badmfkr's Avatar
I grab a hold of the heat shields with a small pair of needle nose pliers never even touching the wire.
then use dielectic grease in boot & anti sieze on plug threads.
Old Sep 6, 2005 | 10:49 PM
black00TA's Avatar
im with everyone else, def a loose wire...
Old Sep 6, 2005 | 10:53 PM
MakoLS1's Avatar
they are all easy to get to from the right angle! Then again, recently Ive changed mine out like 5 times the past two weeks.
Old Sep 7, 2005 | 07:09 AM
Bill Bowling's Avatar
Was the problem a loose wire or a bad one?
Bill
Old Sep 12, 2005 | 10:54 AM
02 SS's Avatar
This weekend I checked and rechecked all of the wires and also felt each of the plugs for cracks or chips, didn't find anything wrong and the car actually ran worse. So I parked it and ordered some wires (MSD's 8.5's)this morning. I'll get them this week and get them installed this weekend. I'll let you know how it goes.
Old Sep 12, 2005 | 01:36 PM
black00TA's Avatar
while your at it, it would be a good use of time too pull the plugs out and re-check them. it very possible that when installing them that u hit the end causing the gap to get thrown off.
just a thought. if the wires dont fix your problem..
Old Sep 12, 2005 | 01:56 PM
11SECSS's Avatar
If you still have your old plugs try putting them back in and see if the problems is gone ....or have someone pull the code so you know exactly want it is might have nothing to due with the plugs....
Old Sep 12, 2005 | 01:57 PM
robertbartsch's Avatar
To get number #8, I remove the starter and get it from under the car.... very easy this way....
...last time I change plugs I took off the alumium plug insulator,,,, no issues yet!
Old Sep 18, 2005 | 09:24 PM
02 SS's Avatar
I installed the wires this weekend, but it did the same thing. So I started pulling plugs thinking I had cracked one of them. I got all of them out and they all looked great. I couldn't find anything wrong with any of them. So I went back to the auto parts store and bought 8 more NGK's. I got those in and now, it runs great. The only thing I can think of is it was a bad plug.
Thanks for the help.
Old Sep 18, 2005 | 09:29 PM
wanklin's Avatar
glad it worked out for you.
Old Sep 19, 2005 | 09:39 AM
TARyan21's Avatar
Generally if it's the plugs especially a cracked one an engine code will not show. I'm with the other guys that it was a loose spark plug wire. I had the same exact thing happen two weeks ago to me. I had advance auto run the code, found what cylinder it was and sure enough it was a loose wire. Three days ago after installing headers my car was misfiring and backfiring due to two cracked spark plugs and never got a code. I'm glad eveything worked out for you I just hate seeing guys spend money and not able to get it back.
Old Sep 19, 2005 | 10:44 AM
For F-bodies, remove the starter from the bottom and plug #8 is easy.
Old Sep 19, 2005 | 11:04 AM
black00TA's Avatar
not necessary. the #8 is simple if u can get it from the underside.
Old Sep 19, 2005 | 01:19 PM
slt200mph's Avatar
No need to pull the starter...get under the car and it is a breeze to do number 8..My car has all the smog stuff off of it and it takes me 25 minutes to change all the plugs..You need a flex head ratchet, 1 inch extention, 3 inch extention, and a spark plug socket to take care of all of them.
Old Sep 19, 2005 | 04:19 PM
stangkiller's Avatar
same thing i did.
Old Sep 19, 2005 | 04:50 PM
davered00ss's Avatar
Moderator
Go from the top. It's easy.
