Do exhaust tips have an effect on exhaust sound/tone?
I'm wondering if they have any sort of effect on the way an exhaust sounds. I currently have the dual dual tips and I'm thinking of getting a pair of 3-4 inch rolled tips. Will this change much if anything?
the resonance and all can be changed by the tips...but goin from what u wanna go to there shouldnt be any difference....Ive heard a difference in the round vs square tips and the size of the tips.....
I switched from a larger tip to a basic 3 inch tip. I like a more mellow sound. I had too much reverberation with my larger tips. If you go from one extreme to the other you will definitely hear a big difference in your exhaust note. Take your tips off and just listen through the tails. You should notice a big difference if you have larger tips.
LS1Tech Administrator
Received 1,788 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yes, a tip change can certainly make a difference in exhaust tone.
Originally Posted by FrozenMonkey
Ell Ess Won, you say it like it doesn't shange the sound at all. In your experiance you thought it didnt. Its proven that the tips DO change the sound.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
When a friend put his corsa on the car we listened to it with and without tips and it was a noticable difference. It sounds a little more raspy/high pitched without em.
