SLP BlackWing LID
BTW The Blackwing must flow fine as I made 399rwhp with it on stock heads w a TR224! My SLP lid fits fine also.
It's hard to get good close up pics with my digi but these should give a good idea.....
Blackwing Pics
SLP Lid
That's resolution most dynos would envy!
Ryan02SS reinerated and showed exactly what I was trying to explain. You can clearly see the flat spots and ridges that interupt air flow. I'm not saying it isn't a good lid, but if your looking for every last hp, you might want to look elsewhere. I wouldn't want my 90mm LSX breathing through there.
the SLP Blackwing and a "LS1 Motorsports"
lid several years back. The two aftermarket lids
were basically unmeasurable drop (at the flow
I was able to obtain) and the OEM lid sucked
***. "A lid is a lid". Though some are prettier,
sturdier or fit better than others.
https://ls1tech.com/forums/generation-iii-external-engine/70694-lid-o-rama-data.html
Holycrap that reminds me, if $$$=HP, then the BlackWing should make threetimes more than the Regular SLP lid.
quality better, and couldn't see a difference in
the pressure drop between the two aftermarket
ones (though the difference to stock was quite
measurable even with the setup limitations).
I've been collecting vacuum cleaner guts to build
a better flow bench; I have 6 "12Amp" Hoover /
Eureka ones now. That might do. Now, just the
small matters of building it and redoing the work...
and wiring the shed for a 50A 115V branch.
The Blackwing piece appears to be a whole different
manufacturing technology (die molded, fiber-reinforced
plastic vs vacuum- or press-formed from ABS sheet)
and I believe the production volume is way low on a
high-startup-cost process. That, and SLP is involved.
Also when I got mine you could order just the lid part + rubber neck and clamp, lots less $$ than the whole package. Of course being SLP they sent me the wrong type (no AIR fitting), and it was sort of scuffed up, but I kept it anyway.
The fact I paid $25 shipped for it, is even better, since it was "just a factory takeoff piece" by the previous owner.
I sold my old SLP lid for $70, so i made money on the deal, with a higher quality "oem grade" part.
i did have to spend $2 on a plastic plug for the AIR hose fitting, since I have a 98, and did the !air/!egr mods.
Ryan
