Installing Long-Tubes?
o and by the way...are whats the difference between clamps and welding besides durability?
As was said, use the search. There's a lot of posts on pacesetters, although you might want to concentrate on the posts for the last coupla' months as I believe they changed the style some. I didn't remove anything extra except the pass side heat shield above the collector. Without access to a lift, get a decent jack to raise the front end up, and some decent jack stands. A $20 floor jack ain't gonna cut it. Good luck.
If I had, my recent heads/cam install would've been a bit more difficult.
Band clamps..... Mine leaked, until I put a GOOD muffler tape under the band clamps, then sealed them down.
HAHAHAHA a 3 day endevor for me, but than again this is the first thing I've ever done to a car other than change a battery and put on a FTRA.
Deffinately go with band clamps...
Kevin
i didnt have to do any grinding, the drivers side is also easy, but one thing i noticed, where alot of people grind or cut the block casting tab on the drivers side, if you push a little hard, the firewall will flex 2mm and the header will slide right up, no modifications necessary. Also i didnt jack the back of the car, just the front, and you need the car higher for the passengers side than the drivers side just because of the shape of each header. i also didnt remove coilpacks or touch the steering linkage. dipstick has to come out.
Didn't take steering shaft loose, though, and just slid the coil packs outta the way.
