ls6 intake?
Old Oct 3, 2005 | 12:57 PM
gr8one99SS's Avatar
Default ls6 intake?
sorry to ask a stipid question but will an 01-02 ls6 intake work on a 99 ls1. i have removed air and egr.
Old Oct 3, 2005 | 01:07 PM
Z28LS1camaroguy's Avatar
yeah, its the same engine and everything just different intake and some other things. and if the EGR is removed then no problem at all.
Old Oct 3, 2005 | 01:12 PM
gr8one99SS's Avatar
thanks i was told my throttle body wouldnt work on the other intake
Old Oct 4, 2005 | 07:34 AM
chris2000ss's Avatar
it will work
Old Oct 4, 2005 | 09:41 AM
Bryan @ Speed Inc.'s Avatar
the only mod you need to make is your coolant crossover. you ahve to get the ls-6 style coolant lines that runs under the intake manifold. everything else will bolt right up w/ no problem.
Old Oct 4, 2005 | 09:45 AM
natronathon's Avatar
i dont think gaskets are needed either, i believe they are built into the manifold... if i remember right... might wanna double check that though...
Old Oct 4, 2005 | 07:01 PM
M6HuggerSS's Avatar
heres mine....
Old Oct 4, 2005 | 07:38 PM
spy2520's Avatar
hey wait a minute. I thought there were 2 different ls6 manifolds. To be clear, we should tell the guy that the z06 one is slightly different from the f-body one in that it has no bracket for throttle cables or something like that because it is throttle-by-wire. right???
Old Oct 4, 2005 | 07:57 PM
Hardtop00SS's Avatar
I have a ZO6 LS6 intake on my car and it had holes for the throttle bracket, the gaskets are not made on the intake, they are basically O rings on each port that you can remove, some people don't change them, but I think the gaskets are like $10 for the pack, I did it when I changed mine, won't hurt to change them or leave the old ones on...
Old Oct 4, 2005 | 10:13 PM
Danny2tek's Avatar
Just remove the bracket of your old intake.
Old Oct 4, 2005 | 11:11 PM
spy2520's Avatar
well that solves that problem.
Old Oct 5, 2005 | 02:39 PM
Trev_SS's Avatar
yep sure will
Old Oct 10, 2005 | 07:38 PM
lrk322's Avatar
What if I have a 99 camaro with Air and EGR. What LS6 instake should I look for?
Old Oct 10, 2005 | 08:07 PM
Danny2tek's Avatar
If you want to keep your AIR and EGR you should get the one from SLP. If your going to dump the emissions then any LS6 will work.
Old Oct 13, 2005 | 09:10 PM
lrk322's Avatar
Alright thanks!
