Head striped out from header bolt...help!
Old Oct 15, 2005 | 09:58 PM
1ORANGEWS6's Avatar
Default Head striped out from header bolt...help!
I replaced my header gaskets because I couldn't get rid of the header leak. When I tried to tighten the last bolt it went in more than half way and then got a little tight but was still moving. Then with about 1/16" left to go it stops. I backed it out cleaned out the hole and tried it again same thing. I cleaned it again this time the bolt strips out the head . It really seems as if my car is evil and it fight me with every mod. What can I do to fix it without removing the head?
Old Oct 15, 2005 | 10:24 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Did you pull out metal on the bolt threads?
You can try a bottom tap and chase the threads.
If that does not work, you may have to drill it larger and use a helicoil or similar. Obviously, if it's a hard to get to hole you will have to pull the head if you can't get a straight shot at it.
FWIW, on my header install I had 2 stock bolts that would not run all the way in. I had a set of slightly shorter bolts that came with the pacesetters , I ended up using two of those.
Old Oct 15, 2005 | 10:35 PM
1ORANGEWS6's Avatar
I did pull out aluminum in the treads of the bolt. What's so F-inf bad is it's the back bolt on the right side.
Old Oct 15, 2005 | 10:45 PM
gwj's Avatar
gwj
#8? That really sucks. There may well be some kind of right angle drill that will get to it, and you could fix it.
Likely you will end up pullin the head though, sorry to say.
Any semi-competent machine shop can install a helicoil, once the head is pulled.
Old Oct 15, 2005 | 11:41 PM
mrhzk35404's Avatar
can you put any washer in to make-up the gap?
Old Oct 16, 2005 | 05:03 PM
Firehawk441's Avatar
I've been there myself. I feel your pain.
Old Oct 17, 2005 | 08:03 PM
1ORANGEWS6's Avatar
What did you do to fix it?
Old Oct 17, 2005 | 09:14 PM
Unfourtunatly I pulled the head & installed a heli coil. Sorry if this doesn't help. Good luck!
Old Oct 20, 2005 | 06:59 PM
1ORANGEWS6's Avatar
FYI...I fixed the threads with an 8mm tap. The 8mm tap is a little bigger than the stock threaded hole but it still works.
