Help picking good spark plugs.....
Old Oct 22, 2005 | 10:25 AM
00Vette's Avatar
Default Help picking good spark plugs.....
I have a 2000 C5 with an M6 and its a H/C car with 10.7:1 SCR. It has full intake and exaust with headers. I want to put good plugs in but don't know exactly what the best is, or where the best place to get them is.
Thanks in advance...
Old Oct 22, 2005 | 11:00 AM
WILWAXU's Avatar
I would try a set of NGK TR55's first, then if the car breaks up on top end switch to TR6's.
With that compression ratio the TR-55's at stock gap should be fine.
Old Oct 22, 2005 | 11:22 AM
KILLERARMY's Avatar
Should I gap the AC Delco Idrium at .060 or leave them at the standard .040 for a 02 Camaro SS? I just want to squeeze as much power I can get out of them.Some say this other say that about what to do with this spark plug.What's the differents between the to gaps? Is the .040 is design to handle little spark power or whatever and the .060 can handle alot more whatever.
Old Oct 22, 2005 | 11:31 AM
00Vette's Avatar
okay..........can I pick them up at my local schucks auto store? and how much do they typically run for a set?
Thanks for your help.
Old Oct 22, 2005 | 01:15 PM
TA BOY's Avatar
Around $2 Each And U Could Pick Them Up At Any Auto Parts
Old Oct 22, 2005 | 01:21 PM
00Vette's Avatar
cool........thanks!
Old Oct 22, 2005 | 06:28 PM
00Vette's Avatar
I went to schucks and had to order them. $3.50 each.
These better be some good plugs...........
Old Oct 22, 2005 | 06:30 PM
davered00ss's Avatar
Moderator
TR55's gapped at .055
Old Oct 22, 2005 | 06:31 PM
Moderator
TR6's for nitrous or forced induction.
Old Oct 22, 2005 | 06:32 PM
00Vette's Avatar
I just ordered the TR55's.........will they work for nitrous? I plan on going with nitrous eventually.........
Old Oct 22, 2005 | 06:57 PM
Moderator
You should run a cooler plug with nitrous. TR6 is the most popular Nitrous plug.
Old Oct 22, 2005 | 09:41 PM
00Vette's Avatar
So I should not spray with these plugs at all? I'll just have to switch out my plugs when I get the nitrous system hooked up. It won't be till next race season anyway. ..........
Old Oct 22, 2005 | 10:07 PM
8GTOKLR's Avatar
I run TR6's and dont have nitro or boost. but I gotta **** load of timing he he i was at 27 degrees on dyno. but street testing was like 25 or so. I am running the 160 stat also with them. i paid like 2.27 ea for plugs
Old Oct 23, 2005 | 09:58 AM
00Vette's Avatar
Where did you get your plugs at for that price?
I figure that before next race season (when I install the bottle) I'll switch out the plugs for the TR6's
Old Oct 23, 2005 | 10:19 AM
GTO_Scott's Avatar
I just paid $1.68 each for NGK TR55s (3951) at Advance Autoparts last night.
Old Oct 23, 2005 | 12:48 PM
00Vette's Avatar
Good to know..........maybe its the location you guys are from? I'm in Washington state.
What do you pay for gas? Its about $2.70 for regular here
Old Oct 24, 2005 | 11:02 AM
GTO_Scott's Avatar
I lived in Tacoma just over a year ago and I'm out in Denver now. We have lower octane here, 85 to 91 but with the elevation it's fine. Gas was $2.65 last night at the corner station.
Old Oct 24, 2005 | 12:12 PM
WS6FirebirdTA00's Avatar
if you wanna do it right you need to find out what your compression is with a compression tester. with a cam tr55 are prob going to be too hot, but taht depends on the cam.
Old Oct 24, 2005 | 03:47 PM
JEB Garner's Avatar
00Vette, For spark plugs, try BRISK plugs. They are expensive but they are the best. You only get what you pay for. So why not pay for the best. BRISK.
Old Oct 24, 2005 | 03:50 PM
how much are they? IMO its not worth paying more, the copper ngk plugs have proven themselves.
