? about headers and true duals
Old Nov 13, 2005 | 09:38 AM
2000WS6TA's Avatar
Default ? about headers and true duals
if i buy texas-speed true dual exhaust kit what headers work well with it? i think the pacesetters will work. but which ones line up the best if im to use them with the texas speed dual exaust. and if i get the off road headers what else do i need to do, i think i need O2 sims and O2 extensions but i know there somthing else i need to do with the AIR system and EGR stuff but im not sure what. thanks for your help.
Old Nov 13, 2005 | 07:47 PM
SgtB's Avatar
o2 extionsions
have your rear 02s deleted whne you get a tune.....sims go bad so they arent worth they money
Old Nov 13, 2005 | 08:56 PM
parbreak's Avatar
Believe they are made to line up with JetHots also.
Old Nov 14, 2005 | 07:06 AM
2000WS6TA's Avatar
what about the air and egr stuff? what do i need to delete that stuff?
Old Nov 14, 2005 | 08:29 AM
DirtyJohn's Avatar
IRRC they are designed for JetHots, Hookers and Pacesetters
JetHots and Hookers for sure. But I am living proof you can make them work on QTP's.
SLP's prob not, and MAC's for sure not.
Correct me if I'm wrong though.
Also, your AIR and EGR is a decision your header selection is based on.
Your cat-back or True Dual setup won't be affected by it.
Your emissions laws in your area should help you determine if you want to keep your AIR and EGR, your exhaust setup should not effect it.
O2 Simms are not necessary if you are going to get a full tune, They can just remove the error code that causes the SES light to come on, or trick it more if your trying to pass emissions. Consider where and when you are going to get a tune too, a good tuner may not be availible near you.
I bought O2 Simms for the rear and regret it b/c I'm going to tune myself and could have just removed the code. Wasted $90 or so.
QTP headers required 12" O2 extensions for the front O2's and I still had some slack to tie up.
I would imagine most other headers would be the same, as the collectorsdont look THAT much different with respect to the O2 bung location.
Anything more and you will have too much slack I think
Good luck bro
DJ
Old Nov 14, 2005 | 09:20 AM
2000WS6TA's Avatar
Thanks for the help. but i just have one more ?. since im using off road headers i wont need the rear O2s right? and since there off road ill need to do somthing with my air and egr stuff. will the block off plates from www.ls1speed.com do the job or is there somthing else im going to need along with the code delete and plates?
Old Nov 14, 2005 | 09:52 AM
DirtyJohn's Avatar
When you say "off road headers" I am going to assume that means headers without the AIR or EGR provisions correct? These are also called "race style".
If so, that means you will not have anything to connect the AIR or EGR parts on the engine to on the headers. That being said, it would follow that you would NOT need block off plates for the AIR and EGR as the provisions on an "off road header" wound not even be present for them to mount to.
Understand?
Basically how it works is, If you buy headers that are "Race style" or "off road" as you put it, you will NOT need the block off plates.
If you DO buy them with the AIR or EGR provisions, it allows you to remove the AIR and EGR hardware from your engine, but gives you the flexibility to replace them in the future.
If you are removing AIR and EGR from your system entirely, no plates needed.
Also, the headers have no bearing on weather you need the rear O2 's or not.
That is only a consideration for everything AFTER the front O2's IE your choice in exhaust. If you have off road Y or True duals, no need for O2's get the codes deleted or pay 90$ for simms. If your planning on being emissions compliant and run cats, you can keep the rear O2's.
Does that help?
please anyone correct me if I am posting incorrect info.
DJ
Old Nov 14, 2005 | 10:54 AM
2000WS6TA's Avatar
what about the air or egr or whatever it is in the intake manifold wont that be gone and need somthing there? thats what i was talking about. i realized all the hook ups on the exhaust manifolds would be gone with race style or off road headers but on the 98-00 intakes isnt there somthing like an air or egr on there?
Old Nov 14, 2005 | 11:42 AM
DirtyJohn's Avatar
For the AIR there is a small hose or tube that you will need to plug with a small screw.
Also depending on if you have replaced your stock air lid or not, there will be a hole to cap for that aswell, as the AIR tubing that goes into is is now gone with the removal of the entire AIR system. There is also an electrical connection that will be hanging loose inside the drivers side headlamp area where the AIR pump was.
The EGR will have a small hole on the intake directly behind the throttle body that you will need to cap. That part can be purchased from several vendors and it has been recommended to go to your local auto parts store and get a freeze plug which will also do the job. Other than that, the EGR has no other plugs that need covering upon removal. There will also be a loose electrical clip that could be tied down or covered once the EGR is gone. No extra parts needed for that though.
I am not tryign to be negative here but I think it woudl serve you well for this install and for future mods to read over This post It will prob answer all the questions you have here, and give you more info on any future induction and exhaust mods you may do. I read this at least 8 times before I made my Exhaust purchases and will prob refer back to it in the future. Plenty of knowledge there, don't just rely on replies in this thread.
Good luck
DJ
Old Nov 14, 2005 | 12:11 PM
MadMike329's Avatar
Sorry to just bust in but does anyone know what exactly the rear o2 sensors do? i put my pacesetter/tsp system on about 2 weeks ago and i just have the rear o2's taped up under the car. does anyone know if this is a bad thing or if it's hurting my engine? i plan on buying an hptuners tuning suite for my laptop and i was wondering if i could delete the rear sensors with that...
Old Nov 14, 2005 | 12:15 PM
TRMIN8R's Avatar
Pacesetters + TSP TD's = teh ****!!! That's what I have and I love it!!!
Old Nov 14, 2005 | 12:18 PM
akZ28's Avatar
They are not needed I know many people including my self who have been driving around for a while with the rears unplugged it wont hurt the engine. They will just throw a code yes you can delete the code.
Old Nov 14, 2005 | 12:29 PM
SgtB's Avatar
they measure the efficiency of the cats
Old Nov 14, 2005 | 12:45 PM
MadMike329's Avatar
alright, thanks a bunch guys... that got a lot of worry off my mind. Guess it's time to dish out another $500 for that tuning suite
Old Nov 14, 2005 | 01:38 PM
V6 Bird's Avatar
Old Nov 14, 2005 | 01:55 PM
TRMIN8R's Avatar
Originally Posted by V6 Bird
Old Nov 14, 2005 | 02:20 PM
akZ28's Avatar
V6 bird please tell me thats not a TSP True Duals kit, I just ordered one.
