Spark plug gap for N/A ~400hp applications
Old Nov 13, 2005 | 01:49 PM
FstBlkz28's Avatar
Default Spark plug gap for N/A ~400hp applications
whats the rule for spark plug gap again, like Stock gap - .004for every 50hp you have over stock?
I've got my tr55's gapped at .051 right now, but I'm going to be swapping em soon so I was wondering what everybody thats cammed and in the 400rwhp ballpark are gapping them at?
TIA
Old Nov 13, 2005 | 02:27 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Well, my cammed A4 LS1 was at about 360rwhp and I was running TR55s gapped @ .055. Worked fine for me.
Old Nov 13, 2005 | 05:14 PM
luv2spd's Avatar
I would say that sounds about right at where you currently have them.
Old Nov 13, 2005 | 05:16 PM
davered00ss's Avatar
Moderator
Old Nov 13, 2005 | 05:48 PM
Country Boy's Avatar
Senior Member
I have the TR55s with 11.2 compression at .055
Old Nov 13, 2005 | 07:01 PM
1BADTALS1's Avatar
not to thred jack or anything but how long do the ngk's usually last.. how many miles?
Old Nov 13, 2005 | 07:09 PM
LS1-450's Avatar
Does it backfire @ all?
Old Nov 13, 2005 | 07:11 PM
LS1-450's Avatar
Should last over 30K. However, a lot of us change between 10 & 20K on average.
Old Nov 13, 2005 | 07:36 PM
FstBlkz28's Avatar
ya i'm cresting the 15,000 mi mark right now and w/ doing the cam and everything and running pig rich for a while before it was tuned i figured it'd be best to get some new ones in there.
Another question, what would be the downside to having them gapped at .055 still even if the car is making 400hp?
Old Nov 13, 2005 | 07:40 PM
SSINFUL's Avatar
Default It's not just hp...
...it's compression.
If you have decked heads, you'll wanna go down. If you have higher compression, you'll wanna shrink the gap.
Strokers bring another factor in: Piston speed. The piston is travelling faster and the spark event has to happen faster, too. This can be adjusted w/ HP Tuners.
Old Nov 13, 2005 | 07:53 PM
FstBlkz28's Avatar
so in other words, if you've got stock heads and still running the stock CR ... you should be running .055? That would make sense
Old Jun 8, 2008 | 04:09 PM
BadLtBlu99TA's Avatar
Default spark PLug gap
so if i have Patriot Stg 3 heads with 11.3:1 compression with a 600lift camshaft with an A4 auto tranni then will .045 Gap for NGK TR55s be ok for a Gap ?
Old Jun 8, 2008 | 04:43 PM
Viper's Avatar
I'm at 11:1 with a 585 lift cam and running .042 gap on TR6's, putting down 431HP. Runs great.
Old Jun 8, 2008 | 10:34 PM
JBIRD02's Avatar
Not trying to hijack, but in addition to changing the gap, aren't you supposed to go a step colder for every 100hp gained?
Old Jun 9, 2008 | 11:06 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I went TR55s gapped @ .055 when the car was exhaust only
Then went H/C and went TR6s at .038
