lots of mods going on...what else do i need?
Old Nov 17, 2005 | 08:01 PM
ls2 bait's Avatar
Default lots of mods going on...what else do i need?
besides the rest of the parts which im still gathering up ill be doing a ported tb, ported maf, ls6 intake, off road pacesetters w/ mufflex y, plugs and wires. car will be getting dyno tuned within a couple days so that will take care of the emissions delete and rear o2 delete. so what will i need and what do u recommend? car is a 99 ss with 11k on it.
ls6 intake/ tb:
-intake gaskets/ tb gasket (will i need new ones?)
-coolant cross over tube
lt's:
-02 extensions
-gaskets (new gm or reuse stockers?)
-bolts (reuse stockers or get a diff type?)
-band clamps
plugs and wires are self explanatory-already have the msd and tr55@ .50
any tips on getting the pass side ones? they look a little ruff on the knuckles.
Old Nov 17, 2005 | 08:25 PM
bshell's Avatar
ls6 intake/ tb:
Gaskets are reusable as long as they aren't cut / broken.
Did you also get the coolant plugs for the back of the heads? Another cross over tube will work as well.
lt's:
-02 extensions
New GM MLS.
If the LTs are brand new, they should come with new bolts.
-band clamps
It took me about 5 hours working by myself in my garage to install LTs + new injectors (already had the intake). Its not hard to do at all, just take your time. The Pacesetter LTs slid up into place very easily and I didn't have to jack the car up that high at all. The gearwrench set that I bought prior to the install was by far the best purchase I made.
Go slow and be carefull when removing the old intake so you don't snap the oil pressure sensor (I didn't, but it seems to happen often). Good luck!
Old Nov 18, 2005 | 11:07 AM
ls2 bait's Avatar
t.t.t.
Old Nov 18, 2005 | 11:23 AM
mxmccarter2401's Avatar
i change number eight plug from under the car, but i already have headers so that probably freed up some room.
Old Nov 20, 2005 | 10:41 AM
Magnet's Avatar
hey when are you doing all this?? im hopefully putting my LT's on in december....i cant wait to start puting my stock pile on my car... lol
Old Nov 20, 2005 | 10:43 AM
TAQuickness's Avatar
ls6 intake/ tb:
lt's:
-02 extensions
-band clamps
spare yourself the trouble of molesting your MAF.
Old Nov 20, 2005 | 05:49 PM
ls2 bait's Avatar
i figured since it was getting dyno tuned afterwords it would be ok. if he has issues ill swap it out. forgot to mention im doing a pulley too. i should have it all by the end of december so ill prob do it sometime in feb. but i want all my bases covered.
Old Nov 20, 2005 | 09:25 PM
it's easier to tune the car with a stock MAF. Lots of good info out there as to why you don't want to mess with it. Just trying to save you a potential head ache.
