HELP!!! Hooker LT driver side
Old Nov 19, 2005 | 01:19 PM
LiquidFire350's Avatar
Default HELP!!! Hooker LT driver side
cant get this dam thing in, anyone got any suggestions, ive got all the plugs out, the steering linkage out and the car is up on 5 ton jack stands
its hitting on the bottom half of the motor mount, the K-member (yes i have a grinder but its old and weak thats a last resort move), and some pot-metal looking thing thats bolted to the block above the oil filter, its got an open end facing up and held on with two bolts
i was thinking of taking that off, will any oil come out of that?
Old Nov 19, 2005 | 01:27 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Probably whatever oil is in the galley held in place by the filter. Couldn't be much. Are you sure you got the front high enough? I had to get mine about 6" higher than Rhino ramps to get my pacesetters in. I took nothing out except plugs. It was a little tight but I told my wife to give it a good shove and it went right up.
Old Nov 19, 2005 | 01:30 PM
im not hitting the ground, i got it up high enough
Old Nov 19, 2005 | 01:33 PM
gwj's Avatar
gwj
I added a little to the previous post. Sorry I have not installed Hookers, just pacesetters. Hopefully someone that has will chime in. Good luck.
Old Nov 19, 2005 | 01:57 PM
marine02ss's Avatar
Remove oil filter,oil cooler adapter block,transmission mount bolt pry engine to passenger side "It will slip in by itself trust me"
Old Nov 19, 2005 | 02:06 PM
DanZ28's Avatar
Another alternitive, pull the long middle bolt out of the motor mount and lift the engine slightly. You have to pull the alternator to do this though...
Old Nov 19, 2005 | 03:38 PM
Ping King's Avatar
pull the coil packs and valve cover, along with the oil adapter and oil filter...should be basically everything out of the way.
good luck.
Old Nov 19, 2005 | 04:07 PM
got it in, took off the thing above the filter, left the motor mount intackt, left the oil filter on
thanks guys, now any suggestions on were to route the O2 wires
i want to get these duals on tonight
Old Nov 19, 2005 | 06:34 PM
well i just stripped out the threads on one of the bolt holes in the head
time for some locktite and a stud
Old Nov 20, 2005 | 03:34 AM
HartAttack's Avatar
that little piece above the oil filter is what you need to take off. A tiny little bit of oil with come out nothing to worry about. then the header will go up, no need to take out any motor mounts our up jack the engine up.
just wiggle it in, you have all the other things right.
Old Nov 20, 2005 | 08:08 AM
thanks guys, they are in now, i did pull the oil thingy off, some oil came out, i just didnt want to pull it and have alot of oil pouring out
