header install
Old Nov 19, 2005 | 03:21 PM
phoenixv8's Avatar
Default header install
Im having trouble installing my headers. Everything seems to be rusted on the bottom . I just finished removing the driverside manifold. I was reading the instructions and i saw that i need to remove the oil dipstick. How do i do that? by the way they are pacesetter lt's. I would appreatiate all he help.
Old Nov 19, 2005 | 03:35 PM
2001NBMZ28's Avatar
From under the car there's a 15MM? bolt attached to the dip stick tube. Remove it and then pull up on the tube from the top, it'll come right out. You'll need a buddy to help you guide it back in when your finishing up.
Old Nov 20, 2005 | 02:09 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
The dipstick is bolted to the HEAD. Once the bolt is out, give it a good pull, it'll come out.
Old Nov 20, 2005 | 05:30 PM
davered00ss's Avatar
Moderator
Unbolt/pull out.
Old Nov 21, 2005 | 08:00 AM
FCar2000TA's Avatar
Veteran: Air Force
Try to unbolt the motor, lift the motor about 4 inches. The headers should slide right in. You might have to unbolt the upper part of the suspension also.
Old Nov 23, 2005 | 07:36 AM
gwj's Avatar
gwj
I spent more time getting the cats off the manifolds
than the actual header install. Rusted up crap, I had
to get a die grinder to remove one nut.
The install was pretty straightforward, I didn't take
anything off or jack the engine up.
You have to get the front end up high enough.
Old Nov 23, 2005 | 01:07 PM
BlackHawk T/A's Avatar
I am installing my Pacesetter LT's as we speak. Don't worry about the manifold to cat bolts, go one step back and unbolt/break the ones that connect to the rest of the exhaust. Those are 10x easier. The manifold+cat assembly will just fall out the bottom of the car in one piece after detaching the O2 sensors.
For the passenger side I just got done removing the coil packs. They all come off as one assembly if you take off the 4 bolts that hold the whole rail of them on. The one furthest back is a real pain though. After pulling the dipstick i'll have a lot more room to work with.
Old Nov 23, 2005 | 06:32 PM
gwj's Avatar
gwj
I was able to get the drivers' side manifold/cat out in one piece. For some reason I could not get the pass side to do the same? That may have been when my $20 jack crapped out and I went and bought a decent one before installing the pacesetters.
