Underdrive Pulley Question
Old Dec 5, 2005 | 08:17 PM
dschmittie1's Avatar
Default Underdrive Pulley Question
I am thinking about getting an underdrive pulley to install while I am doing my cam swap this winter. ASP seems to be pretty popular. Does anybody know who has the best price on them. Also I noticed they have under and over drive alternator pulleys. Does anyone have any experience with these. I don't have any extra electronics and don't plan on adding anything. Any input would be great
Old Dec 5, 2005 | 09:20 PM
WS6FirebirdTA00's Avatar
m6 or a4? i would personally go with a march pulley, i have one and it is great and a lot better than ASP, IMO. one reason beaing its fluid damped
plus its less expensive
Old Dec 5, 2005 | 09:33 PM
Lithium's Avatar
SSU's Drunk Typing Whore
ASP here...love it.
If your an auto you may want to get the overdrive pulley to help with the charging problems that may occur.
Old Dec 6, 2005 | 05:37 AM
It's an M6
Old Dec 6, 2005 | 08:02 AM
i have just the march pully on my m6 and it works great and i have no charging issues
Old Dec 6, 2005 | 04:45 PM
Thanks Anyone know who has the best price?
Old Dec 6, 2005 | 07:05 PM
sidewayz28's Avatar
for an A4 whats the difference between underdrive and overdrive pulleys?
Old Dec 6, 2005 | 07:10 PM
i got mine from thunder, for an auto with an underdrive pulley, sometimes you will get more of a drain on the electrical systems because of the lower rpms than a m6, this means the alt spins slower, charging the battery worse. leads to a dead battery pretty much or with all accessories on you notice dimming lights and what not
Old Dec 6, 2005 | 07:12 PM
mellowyellow's Avatar
Texas speed and performance has a underdrive pulley that I bought it is by powerbond
the same pulley SLP sells but puts there name on it and paints it black. It has the belt retainers on it to keep the belt from slipping off (a common problem for ASP) I did a before and after dyno test on the same day picked up 6.5 HP and 8 HP in the curve.
I also have a M6 and have no charging effects what so ever ...
Old Dec 6, 2005 | 07:19 PM
sidewayz28's Avatar
and the overdrive pulley??? is that more for autos?
Old Dec 6, 2005 | 07:30 PM
overdrive is for the alt. the pulley is smaller so it speeds up the alt. an underdrive alt pulley is larger and slows it down even more. every car, manual or auto gets an underdrive crank pulley as a mod, thats what makes more power, less torque seen from accessories
