ls6 intake
thanks
Yeah, but not with that part#. You've got an LS1 intake. If you did have an SLP intake(you don't) the EGR would join with a big brass fitting, which your's won't have. Better add an LS6 intake to your mod list. I see alot of people selling 01-02 motors after swapping the LS6 intake for an LS1. It seems to be pretty common. It's tempting when a used LS6 is worth $300+, while the LS1 is lucky to command $50.
Yeah, but not with that part#. You've got an LS1 intake. If you did have an SLP intake(you don't) the EGR would join with a big brass fitting, which your's won't have. Better add an LS6 intake to your mod list. I see alot of people selling 01-02 motors after swapping the LS6 intake for an LS1. It seems to be pretty common. It's tempting when a used LS6 is worth $300+, while the LS1 sells for pocket change.
My pocket change anyway.
