Another Stupid Exhaust Setup Question
Here is the setup:
Dynatech stepped LT headers
Short Bullet Mufflers
X-pipe
Carsound 3" Cats
All Mandel bent tubing
I have al these parts that I purchased from a board member two years and never got around to putting them on. I am all about stock look. I have just slightly under stock height ws.6.
The setup I have in mind and have always had is a catted 3" coming off the headers into the bullets and, of course dump into the axle cavity at a 45 degree angle outwards.
Right now I have a flubmaster and it sounds awlful as the passengerside pipe FELL off.
What I really want is a great sounding exhaust (who doesn't) but one that wouldn't drive the wife out of the car everytime we drive together (hmmm, and the down side is?)
My thought is with the Cats, it would kill the sound from the LTs, which is fine. I would like a good idle sound coming from THE car, not the back of the car. But want to be able to have a conversation with the windows up on the highway.
Ideas or alternatives?
Given the give and take, what do you think the final outcome with HP and Torque would be? Do you think it would even justify the replacement of the stock manifolds?
As for the exhaust, I think it will be loud, very!
Your best bet would be to run them out the back, you can either have both pipes going over where the Y would, or get a panhard bar relocation bracket (BMR) this will allow clearance on both sides.
If you are worried about noise, then add some mufflers at the back as well. I recommend Classic Chambered Powersticks, they are compact, cheap and flow so well they won't affect performance.
http://www.classicchambered.com/index.html
You could either arrange the rear mufflers like a GMMG system (transverse):
Or like Stainless Works and have longitudinally:
Damn nice looking! Just of the bat, what do you think the sound comparision will be between the headers and the headers with cats on. My thing is I actually went out and bought the cats (carsound) because I really want them on the car (can't afford the ticket). If it isn't going to be a big deal, then I won't worry about asking the exhaust shop to make me a replacement pipe (cat replacement pipe).
I'd run the cats regardless, as it will help with the sound, keep you legal and won't really cost any HP worth mentioning or worrying about. Unless you need every single pony, which for a road car you probably won't.
