TB Bump Stop Mod ??
Old Dec 13, 2005 | 11:12 PM
98RedBird's Avatar
Default TB Bump Stop Mod ??
I checked my WOT voltage today because I was wanting to perform the Bump Stop Mod, and i found that my WOT voltage was only 4.44VDC. That seemed awfully low to me. I know that 4.70VDC is where I needed to stop so that i did not set an SES light. so i ground it down to 4.69VDC. What I was wondering was will i notice any difference when I get the car out again next spring? i looked at the throttle blade before and after and I could not notice any difference. Does anyone have any experience with this mod? Thanks.
Old Dec 14, 2005 | 02:00 PM
nytmare1's Avatar
You might want to check out: https://ls1tech.com/forums/generation-iii-external-engine/420817-bumpstop-mod-my-first-try-writing-install.html
It's a current discussion...
Old Dec 14, 2005 | 07:57 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Originally Posted by nytmare1
You might want to check out: https://ls1tech.com/forums/showthread.php?t=420817
For sure.
