some exhaust questions
http://ls1sounds.com/Flowmaster/flow...er_stockTA.MPG
And I think it sounds just like what I want, but I have a hard time beleiving all they replaced was the muffler. It looks like the exhaust is coming out of both tips, but on the stock TAs isn't one tip just for show?
And also will this gain me as much power as the dyno muffler and will they cost the same to buy/have installed?
One last question- someone said the dynomouth was just replacing the muffler, but on ls1sounds.com it said-
"This is a homemade system. Typically it is the result of someone who purchases the SLP Loudmouth cat-back, then gets tired of how loud it is so they swap in a Dynomax Bullet muffler in place of the Loudmouth Resonator, hence the name Dynomouth."
whioch ones right?
Dynomouth = Loudmouth - Resonator + Dynomax Bullet (replaces resonator).
Miami Muffler in South Dade can fab one up for you no probem. Actually, they can make any freakin' exhaust configuration you want on site.
http://ls1sounds.com/headers_cutouts...tock_98Z28.MPG
Edit: the link says headers, but ls1sounds says stock headers, stock pipe, flowmaster mufflers, and 3'' cutout.
I think that sounds really great, I'm not sure how much of a differnece in sound the muffler should make when the cut out is open, but the car definitely sounds a lot meaner than all of the other stock/cut-out LS1s I've heard. If I were to try to shoot for this sound and a ~10 HP gain should I get a single or dual cut out and where would be the best place to put em?
Thanks for all the help
Of course you like that sound!- That's the cutout open, not the Slowmaster.
One cutout in the I-pipe right under the passenger seat niche (it's hard not to locate it- it's perfect for a cutout).
2 cutouts involves more skilled fabbing in the Y-pipe, plus you lose ground clearance.
1 is all you need really.
Good luck!
If you like that deep tone, check out Hooker and Magnaflow.
yeah, if I had money I'd get kooks LTs and an x pipe.
BTW how will a cutout affect my o2 sensors? I'm pretty sure they're going bad, I try to cruise at under 1500 rpms and when accelerating keep it under 2 grand (its an auto so I don't have that much control) and I'm still getting like 13mpg. So I might want those replaced soon, and will this affect any of my plans for the exhaust set up?
I too, for cost savings, initially swapped out the stock muffler with a Spintech 3"in/3" dual out.
Then,
Miami Muffler built me these for $450 installed a couple years ago. 3" Mandrel bent aluminized (meanest, baddest setup I've heard yet on any car). I later swapped out those Flowtech Afterburners for some Magnaflow 4x9's to quiet things down.
My final, favorite, and surprisingly very very high flowing setup was this:
Listen to ls1sounds very well. That resource wasn't up and running when I made my first 3 decisions. I did consult it for the SLP 2OTL and was very happy with my choice.
Good luck!
