Anyone with the TSP True Duals...
If it's hitting, you should be able to see the pipe touch the floorboard.
Mine hit until I got poly motor mounts. I rigged it until I got them by using a piece of high-temp hose between the pipe and the body, held on by a radiator clamp.
Hope this helps.
Mine did the same thing but only during WOT. You should be able to see where the pipes have been hitting due to the paint being rubbed off. Nothing a sledge hammer won't fix
. Trending Topics
Might just need to beat and bang on somthing to make a little more clearance clarence. Make sure all the clamp bolts are oriented as to not hit anything.POLY mounts are the only way to go. Also, you could take off your tranny mount and make sure it isnt broken. I've got poly motor/tranny mounts on my car (with TSP duals), and love them. Car feels iike a rock now.
Also, at exactly 1900 rpms, i've got the meanest resonation you've ever heard. Does anyone else experience this?
He said he can't even hear himself think at certain cruising rpms.
Other than that no weird noises coming from it or anything. I have noticed I cannot hear anything in the car though, and barely the stereo. It is worth it though, for it to sound like a Killer!!
