Engine Motor Mount Bushings!!!
Old Dec 27, 2005 | 10:19 PM
Haans249's Avatar
Exclamation Engine Motor Mount Bushings!!!
Hello Everyone,
I need information or instructions about installing the poly motor mounts! The search isn't working, so I couldn't dig anything up.
If anyone has any information, other then its a big pain in the A$$, or a link to great instructions, that'll be great!! Right now my vehicle has no heads or headers on it, so I can only imagine that it'll be pretty easy.
Thanks!
Adrian
Old Dec 27, 2005 | 11:05 PM
FDLS1's Avatar
I just did the mounts about a week ago. I don't have an F-body but I am using the mounts, so i know how to do the mounts just not what you need to remove in your car to get to them. Ok, unbolt and remove mounts from the car, drill out the rivets till the two peices of steel come apart, you might have to heat or scrape to get the rubber insolator seperated from the steel parts, after that it is too easy install poly mounts and bolt the two steel plates together with the nut and bolts supplied. TIP, do one and check it on the car to make sure you put the poly mount in the right way...
Hope this helps.
Old Dec 28, 2005 | 12:15 AM
Haans249's Avatar
Thanks!!
Anyone have any links?! More information?!?!
Adrian
Old Dec 28, 2005 | 06:07 AM
corvet786c's Avatar
Smile
I bought the Polyurethane mounts,You have to get the shell out and the rubber stock mounts are in place,take them out put new ones in, my shell was welded back rather than bolted back on. No other rubbing header issues now.Works great if you ask me.
Old Dec 28, 2005 | 08:43 AM
Haans249's Avatar
thanks for the input corvet, what do you have to remove, and not remove? I'm about to tear into her and pullout the ac and altenator to get to all the bolts I need....
Adrian
Old Dec 28, 2005 | 09:57 AM
jtmiller92's Avatar
What brands are you guys using? Prothane?
Old Dec 28, 2005 | 10:17 AM
HavATampa's Avatar
Wrong section. Check the "External" Engine forum and you might find more answers. There is a thread about this on the first page, so no search is involved. They are real easy to do with no heads and no headers. Prothane is the brand I used and come with good instructions. Worthwhile mod to do IMO.
Old Dec 28, 2005 | 10:55 AM
jtmiller92's Avatar
i didnt notice it was in the wrong place.
Old Dec 28, 2005 | 07:55 PM
Haans249's Avatar
Ok, its alright, I didn't realize I put this in the wrong thread, you are right!!
Anyways, I got them installed today, took the whole day sadly had to do some pain in the *** stuff with it. I did also have my heads and headers off, made things a million times easier. Anyhow, thanks!!!
Adrian
