What to expect from SLP LT's
Old Dec 28, 2005 | 05:21 PM
FUN LS1's Avatar
Default What to expect from SLP LT's
First off, I already had a Loudmouth exhaust before adding the SLP LT's, and there was a noticeable improvement in tone and volume after installing the headers.
I'd estimate 20 rwhp gain...
You should expect to hit these headers on a lot speed bumps, dips in the road, etc. Take a look at the first pic... The SLP LT's hang way low, and are definitely not for a lowered car.
I wasn't satisfied with the thick/skinny band clamps supplied by SLP, and I've got a couple of wicked exhaust leaks. See pics 2 & 3. I can't wait to redo them with better materials. There's not much room between the O2 sensor and the cat, though. Doh! We'll see how far I can knock the exhaust back before re-clamping them.
Attached Thumbnails What to expect from SLP LT's-header_bash.jpg   What to expect from SLP LT's-pass_collector_leak.jpg   What to expect from SLP LT's-driv_collector_leak.jpg
Old Dec 28, 2005 | 05:33 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I just got horrible tranny prying flashbacks.
Congrats on the install. They're better than no LT at all, so enjoy.
They can support a stock internal or cam only setup no problem. Anything after that, you're giving up hp/tq to other brands.
I lived with them for about 18 months and they did their duty.
Old Dec 28, 2005 | 07:28 PM
Stoichiometric's Avatar
Just curious if you would have any problems with the o2 being close to the cat?
Old Dec 28, 2005 | 07:32 PM
FUN LS1's Avatar
I haven't had to pass emissions since I added the headers, but it has passed regualr VA inspection since. I don't see why it would be a problem there, and there's not a lot of room on the collector to put it somewhere else.
Old Dec 29, 2005 | 01:44 PM
SUX2BU's Avatar
SLP's are pretty much the bottom of the totum pole as far as long tubes go (performance wise).
Old Dec 29, 2005 | 01:50 PM
STANG KILLA SS 2's Avatar
thats what i have, but when i bought them they were pretty much the only choice , the rumors of the hookers were just coming about when i bought mine..
o and i welded mine solid instead of using the band clamps.
with all the mods i have now im sure im giving up a ton of HP
Old Dec 29, 2005 | 09:43 PM
black01_WS6's Avatar
you will be hitting you head against the wall with these headers, and will change them after hitting them on every pothole, and speed bumps.
Old Dec 29, 2005 | 09:49 PM
227Hawk's Avatar
They do hang LOW
But the positive side is ......................
Wait, there isn't one. Well you have headers
Hawk
