no cats=bad sound???
Old Dec 29, 2005 | 06:51 PM
SLP/Drew's Avatar
Default no cats=bad sound???
my system im gona get is gona be LT's y-pipe cutout and a muffleer with no cats at all. I know open its gona sound raspy and loud as hell but with the cutout closed will the system still sound crapy???
Old Dec 29, 2005 | 06:55 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just rasp really imho.
SSilverSSurfer's Avatar
what kind of muffler? its gonna be hella wide open
Old Dec 29, 2005 | 08:59 PM
SLP/Drew's Avatar
flowmaster exaust thats why I want to get a single cutout...of corse if I do this my system will not have any cats...I just dont want it to sound crappy...
Old Dec 29, 2005 | 09:06 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
took mine off...cutout...flowmaster....everyone says it sounds MUCH better without the kittens.
Old Dec 29, 2005 | 09:36 PM
black01_WS6's Avatar
your system will still sound like ****, because you have the flowmaster on. it is hurting you more than helping you. If you get a good catback then you wouldn't need the cutout. unless you wanted the sound.
Old Dec 29, 2005 | 09:39 PM
98Red5.7's Avatar
i got corsa with no cats and it sounds great except at wot when u let off alot of the time it will back fire but other then that it sounds alot better
Old Dec 29, 2005 | 09:53 PM
227Hawk's Avatar
Cats or bullets will stop the rasp.Or spring for duals otherwise you will have RASP.
Hawk
Old Dec 29, 2005 | 09:59 PM
CBX's Avatar
CBX
What do you guys think my setup would sound like without the cats?
Old Dec 29, 2005 | 10:00 PM
tschmidt098's Avatar
i have true duels with no cats and magnaflow mufller and it sounds awesome no RASP what so ever sounds like an old muscle car
Old Dec 29, 2005 | 10:13 PM
LS69TA's Avatar
I like how mine sounds with the stock exhaust, cutout, and no cats. But my favorite is my old setup I had on my Camaro with no cats,x-pipe, and 1-chamber Flowmasters
Old Dec 29, 2005 | 11:02 PM
SLP/Drew's Avatar
what exactly causes rasp???? Before I thought it was just no cats. but it sounds like it mike be becasue of the y-pipe.
I want a single cutout no cats with my LT but I really dont want to regret my decision
Old Dec 29, 2005 | 11:22 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
A single Flowmaster 80 series crossflow muffler will rasp with no cats. Personally I don't think it sounds very good. Now, true duals using two Flowmasters will sound great with no cats.
Old Dec 29, 2005 | 11:36 PM
00'WS6Rocket's Avatar
I have bullets and when I had no cats it made no rasp, and it sounded awsome, but to each his own.
Old Dec 29, 2005 | 11:41 PM
Ell Ess Won's Avatar
I have lt's, no cats, Ypipe, and a cutout and its LOUD and raspy, and pops when you let off the throttle!
Old Dec 30, 2005 | 08:20 AM
jimmyblue's Avatar
Moderator
I believe rasp is from "sharps" in the plumbing; something
creates unpleasant high frequencies and sharp edges in
the air stream is my pick. Like people say gutted cats make
rasp, but I dressed off all the sharp edges inside mine like
the assembly inserts, and they sound mellow (lust a bit of
boom at 2500 or so where they are resonating). Look inside
your Y merge and it probably looks like hemmorhoids - both
the TSP Y, and the Jet-Hot Y I have, have pieces of one
pipe sticking well into the other side's flow-trajectory.
Like a grass harp. Only decent looking Y is the QTP, that
I've seen.
Cats are mufflers for everything upstream. But you can run
clean plumbing without rasp. It's second-rate fitup for the
welding, that's the culprit IMO. Happy hours on end with
the die grinder up in there, to get it clean (if you can even
reach, or see).
Old Dec 30, 2005 | 12:21 PM
Ice Knight's Avatar
So with cat-less True Duals you will get almost/no rasp?
Old Dec 30, 2005 | 01:25 PM
LS69TA's Avatar
Yea, it's possible. My TD's I had on my Camaro had no rasp at all. Just really loud and deep.
Old Dec 31, 2005 | 04:08 PM
With mine I had no rasp ie. 2.5inch xpipe duel exhaust/long tube headers, and twister mufflers
Old Dec 31, 2005 | 04:45 PM
FUN LS1's Avatar
I loved the back fire from my stock Cat, LM, & Predator tune, before I got the LT's.
I have LT's, cats, ORY, and LM now, and I think it sounds as good as any cat-free car I've heard so far. I have to pass emissions tests in VA, too. No more back firing, though
