true dual kit?
Old Jan 8, 2006 | 02:34 PM
colorado04's Avatar
Thumbs down true dual kit?
can someone please give me names of people who make true dual kits for a 98 fbody. the search here isn't working and google didn't help. I believe i read on here that people sell kits
Old Jan 8, 2006 | 02:40 PM
MattZ28's Avatar
www.jegs.com
www.summitracing.com
Universal X-pipe kit
Turndowns
Dynomax Bullets
Flanged reducers
Old Jan 8, 2006 | 02:42 PM
Nate_Taufer's Avatar
texas-speed.com
Old Jan 8, 2006 | 02:50 PM
RGR Pete's Avatar
I thought I read Bassani just started making a true dual for F-body.
Old Jan 8, 2006 | 02:53 PM
70Stang's Avatar
Texas-Speed.com - I have this on my car and I can't say enough great things about it. It seriously was so simple to install, sounds great and has great build quality.
You don't have to fab up anything, just piece it together and you are good to go.
Old Jan 8, 2006 | 04:08 PM
Camaro99SS's Avatar
Summit and Jeg's kits will need to be tweaked by a muffler shop, but it will be cheap. Also, Lane is still building true dual pieces. His are welded and come with everything needed.
Jason
Old Jan 8, 2006 | 04:31 PM
z28convert's Avatar
i am having a flowmaster universal kit from jegs put on as we speaker. it cost 89.00 and mufflers were 75.00 each. tsp duals i think are 300 dont qoute me.
Old Jan 8, 2006 | 07:04 PM
99camaroB4C's Avatar
Someone is selling some on e bay item #8016803991. not sure if that is what you are looking for though.
Old Jan 8, 2006 | 07:09 PM
BlutVonSchwachen's Avatar
I wouldnt suggest getting the ones off ebay. My friend did that from the exact same guy, and he already has those up for sale and is looking for a new setup. They give you maybe 2" clearance, dont sound at all like they should, and I have seen pop corn that looked better than the welds on the peices. Trust me, he had to get them welded again because just by looking down on of the peices you could see atleast 3 spots were light came in. And when we hit it with heat, it pratically came apart. I highly recommend you dont get that off ebay.
Old Jan 8, 2006 | 08:57 PM
lowchevy2go's Avatar
texas speed is whats on my car, but if you go with these and dump it off before the axle i recommend welding the rear hangers to the floor pan and not bolting them, after ripping the bolts out 100 times i finally welded then. If you dont have solid motor mounts the exhaust flexes and will pull the bolts out.
Old Jan 8, 2006 | 09:01 PM
Mike2000Z28's Avatar
I wish someone would make a true dual to run out the back and the SLP CME would be real sweet.
Old Jan 8, 2006 | 09:07 PM
70Stang's Avatar
How much is the shop charging you for the install?
Old Jan 8, 2006 | 09:41 PM
dlandsvZ28's Avatar
As stated previously Bassini does. Here are some pics.
You can get aluminized or stainless. Aluminized compare in price to a Borla Catback stainless.
http://www.stealthram.com/2000pontiacformula.html
Old Jan 9, 2006 | 12:57 AM
TheBlurLS1's Avatar
That's what she said...
If you go to a hardware store, they sell these special washers called "fender washers". They are oversized and will NOT rip through. I used 3/8" bolts, fender washer on both sides, and a ny-loc (sp?) nut. Had them hanging from two different places and they havent even pretended to rip out.
Bolting them will work just fine if you have the right equipment
With enough tweaking and work, i've got my TSP system riding pretty. Had to bash in one of the bullets a little to clear the rear floor pan, and am going to have to dent a small crossmember under the driverside floor board, but other than that, easy as pie
Here's some pics.......
Old Jan 10, 2006 | 06:02 AM
z28convert's Avatar
Default reply to 70Stang
I only know what he is gonna charge me for the headers but id say because he is making pipes to go all the way out the back no more than 250
Old Jan 10, 2006 | 08:05 AM
V6 Bird's Avatar
that looks like *** from the rear!
Old Jan 10, 2006 | 09:17 AM
RDISADEIFAN's Avatar
Jason
Is this a kit I can order from Lane,and what is the price on it.Oh forgot what are the pipes made of and do they exit out the rear.Thanks.
Old Jan 10, 2006 | 12:34 PM
jimmy 2 Times's Avatar
you mean like this
Old Jan 10, 2006 | 02:18 PM
10thAnivHawk's Avatar
<edited>
*Please to not post contact information for non-sponsors.
Old Jan 10, 2006 | 07:32 PM
V6 Bird's Avatar
Originally Posted by jimmy 2 Times
you mean like this
those do look pretty nice. pretty much how id build the CME setup. Ive got one of the guys asking me to build something similar and thats how i drew it out in my head.
