TPS voltage??
Old Jan 12, 2006 | 08:30 AM
rgaynor85's Avatar
Default TPS voltage??
ok at the moment not having money im doin all the small free mods i like to gain a few small "hp", that and i like to work on my cars and i got the ich lol, so anyway i read about the throttle blade not opening 90* and that u can grind down the bump stop to make it open 90* and from what ive read on installuniversity u can watch the voltage till u get 46-47v reading on the tpsbut they said they monitored it thru autotap. ok heres my question, do you need autotap to read those volts or can u just check it with a voltmeter, and if u can just use a voltmeter what wire is it u need to check exactly im not sure.
Old Jan 12, 2006 | 10:03 AM
FRDnemesis's Avatar
The only way to check it without scanmaster, autotap, Tech II or some other computer device, is to pierce the wires with the meter leads and I would not recommend that since it will allow moisture to introduce itself.
Years ago Mid-America used to make insert connectors with leads on them to connect to a multimeter. But I believe that was only L98 & LT1 stuff. They were nifty little tools until the scanmaster came along.
Old Jan 12, 2006 | 04:29 PM
Zymosis's Avatar
You don't have to pierce the wire, you can get a small piece of wire into the plug, or stick the multimeter down into the other end of the plug (all without cutting / exposing wires)
If you do it with a voltmeter, there is a great write up on this site
https://ls1tech.com/forums/generation-iii-external-engine/420817-bumpstop-mod-my-first-try-writing-install.html
I got mine to 4.69 - 4.70 volts and called it good.
