rear pass manifold bolt
Old Jan 14, 2006 | 02:20 PM
Rothman's Avatar
Default rear pass manifold bolt
How the hell do I get that thing out? I cant even reach the plug wire to move it out of the way. Please, any suggestions?
Old Jan 14, 2006 | 02:34 PM
dschmittie1's Avatar
from under the car. much easier for down there
Old Jan 14, 2006 | 02:36 PM
Lithium's Avatar
SSU's Drunk Typing Whore
You talking about that the spark plug? or the intake manifold bolt? Coil pack bolt? kinda lost.
Old Jan 14, 2006 | 02:46 PM
Rothman's Avatar
the exhaust manifold bolt. But I cant reach the plug wire to get it off and make clearance enough to get a wrench on the bolt. I'll try from under the car but when I looked at it from there I could barley even see it.
Old Jan 14, 2006 | 02:50 PM
Lithium's Avatar
I got mine off from the top pretty easy actually. But I am a skinny kid so I can reach back there no problem.
Under the car is a better choice. I did that once and got to it really easily as well.
Old Jan 14, 2006 | 03:02 PM
Rothman's Avatar
I have monsterous hands and can't fit them back there. I think it wouldn't be so bad from under the car but I need to get the plug wire off to do that. I just can't seen to get in there to get it off. So now the problem becomes how do I remove the plug wire with my giant hands not being able to fit.
Old Jan 14, 2006 | 03:20 PM
Lithium's Avatar
You should still be able to reach it from under the car.
You removed the coil packs and egr/air right?
Old Jan 14, 2006 | 03:51 PM
Rothman's Avatar
Didn't remove the coil packs but everything else is out. I don't even Have a wrench /socket anything that will fit up there. I was able to get it moving a little with a gear wrench from above but, it's only a matter of time before my thumb that I'm turning it with decides to stop working.
Old Jan 14, 2006 | 04:07 PM
Rothman's Avatar
finally got it out with the gear wrench. I really wish I had smaller hands because that was a bitch. Thanks guys.
Old Jan 14, 2006 | 04:42 PM
Ice Knight's Avatar
skinny kid + LS1 = a good relationship between car and driver.
Big hands don't mix.
Old Jan 14, 2006 | 06:08 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Yeah, well it ain't no easier with OLD hands either.
Old Jan 16, 2006 | 09:24 AM
WILWAXU's Avatar
Removing the coil packs free's up the most amount of room.
Old Jan 16, 2006 | 09:46 AM
Rothman's Avatar
geuss I missed that. Wish I wouldn't have.
