sweet thunder in loudmouth
Old Jan 18, 2006 | 10:34 PM
Trevor99TA's Avatar
Default sweet thunder in loudmouth
I have the 18" S.S. sweet thunder in place of the stock resonator and don't care for the sound. It makes this sort of rushing air sound more than it does an exhaust note. It sounds really mean and aggresive until around 4k rpm's then kind of a whoosing or a ppssssshhhhht sound unti redline and does this through all gears. I bought it with the ST already installed so I don't know what a regular loudmouth sounds like. Could it be the 2.5" core of the sweet thunder is just too restictive. The car sounded 100x better when I removed the factory muffler and didn't make that damn rushing air noise. Does anyone else have this set-up or know whats causing this noise???
Old Jan 18, 2006 | 10:40 PM
Lithium's Avatar
SSU's Drunk Typing Whore
The 2.5 core is not going to be that restrictive at all on a realitively stock car. You may want to just switch it out to the regular loudmouth...but that is wierd, you sure you just are not imagining it? lol.
Old Jan 18, 2006 | 11:18 PM
Trevor99TA's Avatar
I wish I was just imagining it! lol On my 99 I had a cut out and it didn;t make this sound. When I bought the LM I cut off the factory muffler and it didn't make this sound either (actually it didn't sound to bad). When I put the LM on, the sweet thunder was aleady installed. I installed just the I-pipe with ST already installed and fired up the car just to hear what it would sound like and was dissapointed right away. A lot quieter than a cut-out or no muffler at all. When I revved it I noticed this crappy kind of rushing air sound with hardly any tone to it. It reminds me of an old 70's station wagon with a 4 bbl carb. when you floor it. It does sound incredible if you run the rpm's up slowly, but once you stand on it the aggresive sound goes completly away and changes as if the air is rushing too fast through the Sweet Thunder.
Old Jan 19, 2006 | 05:39 PM
Trevor99TA's Avatar
anyone??? I know there are some cars with sweet thunders in place of bullets.
Old Jan 19, 2006 | 05:41 PM
taintedmeat's Avatar
Sure it's not welded in backwards?
Old Jan 19, 2006 | 06:12 PM
Trevor99TA's Avatar
I guess I don't know. Is there an airflow direction to them?
Old Jan 20, 2006 | 09:47 AM
LS1Zedder's Avatar
I think the open end of the baffles need to face forward. Could be a leak somewhere too. I really want to do this to my LM as well.
Old Jan 20, 2006 | 12:23 PM
Trevor99TA's Avatar
Guys, I've talked to Siler02TA and his also makes that same swooooshing air sound. You might remember hearing his sound-clips of a Sweet thunder installed in I-pipe. My car does sound like his when revved up, but I hate the sound under WOT. I do remember looking inside before putting on and it is installed the correct way as stated above.
Old Jan 20, 2006 | 07:53 PM
Full-Force's Avatar
Its probably the sound of the exhaust going through those fins inside of it.
Old Jan 22, 2006 | 04:52 PM
LS1 Hawkeye's Avatar
I don't have the SS one, just the normal one, but the only noise that I get is the one from the lid. Do you have anyother mods???
Old Jan 23, 2006 | 07:52 PM
98Trans's Avatar
Damn, I wanted to run a Sweet Thunder in the I pipe of a Rumbler too. I was thinking about doing it for a while, then I heard Silver02TA's car and thought I'd go for it. I think it sounds awesome in his clip.....but I dont know, is this "swooshing" really that bad???
Old Jan 24, 2006 | 05:23 PM
Trevor99TA's Avatar
The sound really bothers me. I can't tell you if other people can hear it, as I've yet to have someone else drive the car past me. You will definetly notice in the cabin though. Put it this way, it's enough to where my wife and others will ask why the exhaust sounds like that.
Old Jan 24, 2006 | 05:51 PM
Silver02TA's Avatar
here's a clip of the said 'swoosh' noise..
http://www.ls1poweredta.com/videos/s...underincar.wmv
no more of that for me next month.. LTs/ORY/Hooker here I come
Old Jan 24, 2006 | 09:09 PM
Trevor99TA's Avatar
That's it! Thats the noise! VRRRRROOOOOMM--SSSHHHHHHTTTTT
Old Jan 24, 2006 | 10:09 PM
98Trans's Avatar
Hmmm, I wonder if a Stainless Works chambered muffler would make the same sound. Probably wouldnt be as loud as the Sweet Thunder though.....I'm confused on how to get a LOUD cat-back setup once again
