which series Flowmasters???
Old Feb 5, 2006 | 11:08 AM
WANARUNM's Avatar
Default which series Flowmasters???
Is there any way to tell which series Flowmasters you have. One was on the car when I bought it. I heard the cross flow model was a litlle better than the other series. Probably gonna sell it just want to know what it is.
Old Feb 5, 2006 | 11:30 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Actually, the crossflow (80 series) is the one that flows the worst....
If the muffler is a single offset inlet/dual outlet, then it's an 80 series crossflow.....
Old Feb 5, 2006 | 12:20 PM
REDWS6ROCKET's Avatar
none, flowmaster does nothing for an ls1!!!
Old Feb 5, 2006 | 10:49 PM
WANARUNM's Avatar
Thank ya! May just put a cut out in front of it since its kinda low toned anyway.
Old Feb 5, 2006 | 10:58 PM
taintedmeat's Avatar
Plenty of people with the single chambers on their duals that would say otherwise.
Old Feb 5, 2006 | 11:25 PM
Scotty-Z's Avatar
If using Flowmaster for duals... that's fine. Just use the single chamber ones.
If using the catback or planning on buying it that uses the 80 series? Stay away!
Old Feb 6, 2006 | 12:30 AM
Speed Density's Avatar
hashtagBMW
They dont flow for **** on anything. Cept ricers.
Old Feb 6, 2006 | 01:03 AM
just-a-z's Avatar
It's not bad if you plan on running a cutout
Old Feb 6, 2006 | 10:10 AM
8banger's Avatar
Single chambers are nice. They sound good and aren't nearly as bad as other FM's flow-wise.
Old Feb 6, 2006 | 11:35 AM
LS69TA's Avatar
Old Feb 6, 2006 | 11:40 AM
vodas00ss's Avatar
my buddy had single chambers welded to the end of his long tubes, he took thoes off and replaced it with a 3 inch dual x pipe system with 12 inch bullets, and picked up 18 rwhp.
Old Feb 6, 2006 | 12:32 PM
BAN-LS1's Avatar
That prob has a lot to do with the lengths on the pipes and x more than it does with muffles. Noticed why sprint cars run extensions off their headers? I wouldnt count this as credible info inless you said he swapped his 3 inch dual x pipe 1 chamber system with 12 inch bullets and picked up 18hp.
Old Feb 6, 2006 | 12:51 PM
~JOSHUA's Avatar
A low restriction exhaust actually adds hp compared to open headers. Besides, the LS1's are known for wanting a bit of back pressure.
Old Feb 6, 2006 | 02:32 PM
JBIRD02's Avatar
I was thinking the same thing. Running mufflers right off the headers as opposed to a x-pipe setup is comparing apples to oranges. I would like to see if theres a hp difference with just a muffler swap though.
yep, I would be one of those people!
Old Feb 6, 2006 | 03:01 PM
jmm98LS1's Avatar
Me too!!
