Polyurethane Engine Mounts. Yes or No? Pros & Cons? (edit)
Someone recently told me NOT to because the car was my daily driver. What are the pro's and con's with these? Are they that bad for a daily driver? What should I expect to experience?
Thanks for ANY and ALL information that you can provide.
and i grinded off the 2 bumps and dident use the preload plate and i dont get any vibrations
Thanks again everyone!! Now to get the True Duals and Headers so I can start the install!!
Sorry to re-hijack, but what trans mount are you guys running? The two I've seen available look to be too big for ls1 cars. I know that the Energy Susp. one is too big. Granted, some people have "shaved" them down, or not used the preload bar thing, taken them to a belt sander, etc. I don't know much about the Prothane trans mount, but it looks like it's also bigger than the regular rubber mount that keeps the pinion angle correct.
The poly transmount on the other hand created a few vibrations that I could not tolerate on a daily driver. But I had to use it because for some reason the stockers were too soft causing my trans to hit the floor on hard shifts.
Go for the poly motor mounts, they are great. Just don't get solid ones for a daily driver.
Alot of my wheel hop went away after the poly trans mount, and my shifter barely moves at all now.
