LS6 swap
Old Feb 16, 2006 | 12:50 PM
GA/TA's Avatar
Default LS6 swap
finished my ls6 intake swap and now my oil pressure gauge doesn't work.Anyone know what that could be?
Old Feb 16, 2006 | 12:54 PM
TheBlurLS1's Avatar
That's what she said...
You broke your oil pressure sending unit. It is right behind the intake manifold and gets broken by about 80% of 1st time intake swappers.
You can get a new one at the dealership.
Its a black plastic piece sticking straight up with a plug in the top of it. VERY easy to snap off.
Might want to make sure you're not spewing oil everywhere or somthing in case of extreme snappage. New one just screws in.
Old Feb 16, 2006 | 12:56 PM
GA/TA's Avatar
thanks about how much is the dealership going to rape me for?
Old Feb 16, 2006 | 01:57 PM
89tang's Avatar
You can get these at advance auto parts i got mine from them $37. And yes i broke mine on the intake swap too haha.
Old Feb 16, 2006 | 02:21 PM
GA/TA's Avatar
any ideas as to how to get the old one off?
Old Feb 16, 2006 | 02:25 PM
thunderstruck's Avatar
probably be easiest to remove the manifold again and use vise grips
Old Feb 16, 2006 | 02:26 PM
zspot98's Avatar
It takes a special socket that you can also get for any auto store. There is no need to get any of these parts from the dealer. Also welcome to the club for breaking your oil pressure sender, it's got a lot of members now... trust me I'm one.
Old Feb 16, 2006 | 03:12 PM
TheBlurLS1's Avatar
I was one of the HIGHLY skilled mechanics who DIDDNT break it, either time i took the intake manifold off.
I diddnt know about buying it from an auto parts store though, it'll be a helluva lot cheaper than the stealership!
Old Feb 17, 2006 | 07:48 AM
GA/TA's Avatar
I got one for like 27 bucks. but could i change it out without taking the manifold back off, like maybe just move all the vacum lines out of the way?
Old Feb 17, 2006 | 08:32 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Man, I knew it before i read 9 words into his post that it would be this.
Old Feb 17, 2006 | 09:43 AM
TheBlurLS1's Avatar
Highly doubtful. By the time you got through cursing and bitching about you hand not fitting, you could have taken the manifold off and put it back on.
You've already done it once, so it will go alot faster this time.
When you remove the intake, make sure you broke off the plastic clip(s?) that holds the knock sensor wire to the stock coolant tube. Lots of people forget this and do not get a proper seal because the intake rests on it instead of the heads.
Old Feb 17, 2006 | 01:11 PM
89tang's Avatar
You know i thought i was one of those HIGHLY skilled mechanics cause i took the old intake off without even bumping that sender how i don't know cause i had no idea how fragile it was. Then i read becareful with it and i go to put the new intake on for a test fit and SNAP! Broke the SOB in half .
Old Feb 17, 2006 | 04:48 PM
VORTECFCAR's Avatar
I broke mine during my intall too. Dont feel bad. Autozone has a special socket that worked great for the install BTW.
Old Feb 18, 2006 | 01:46 AM
TheBlurLS1's Avatar
Ahhhhhh yes, the excitement was too much for you my young Padawan!
Make sure you also get the vacuum lines hooked up right or you wont have power brakes and you wont be able to switch the a/c from defrost to vent to floor either! Thats the tiny line going over to the HVAC.
Old Feb 18, 2006 | 02:24 AM
Mike2kZ's Avatar
I broke it too heh.
Here's a Tip: Buy the special socket and leave it on the sending unit after you replace it. Make sure the socket is correctly in place (pushed down). If you leave it on when putting the intake back on, it acts as a shield for the sending unit since it contacts metal and not the plastic sending unit. Once the intake is back on, reach back and just pull off the socket. Just do this every time you take the manifold on and off and you'll never break it again (negligence aside).
Old Feb 18, 2006 | 07:12 AM
squealingtires's Avatar
how 'bout some tips for not breaking it for first timers other than be careful.
Old Feb 18, 2006 | 07:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is the only tip. They just need to be aware that it is there and that "yes" it can break if it is fudged around a bit.
Old Mar 4, 2006 | 11:15 AM
98REDZ's Avatar
I would just love to know what the special socket was or how to know im getting the right one,..I broke mine off as well and was trying to pull the black ring that i broke off inside the metal and it was just not working. very confused!
Old Mar 5, 2006 | 07:53 AM
RaNsOm's Avatar
I was one of the lucky ones who didnt break it on their first time
Old Mar 5, 2006 | 08:29 AM
Z28LS1camaroguy's Avatar
ive read a thread where if you turn the manifold to the right when pulling it out it misses the oil pressure sending unit and comes out perfect without breaking anything, anyone ever done this little trick and if so does it work??
