Are Ported Throttle Bodies Worth It On a Bolt On Car??
My mods are in my sig. below. I've been reading up on the MMS, MTI, and Thunder Racing's ported throttle bodies. MTI states that their TB will flow another 100 cfm over stock and that it's possible to see another 7 to 10 rwhp from their unit.
Right now I'm pulling 316 to the rear wheels and my question is: would I potentially gain any power with a "ported" TB and basically a stock motor?? I do plan on doing a cam and LT's next year but I'm wondering if it's worth it now or not. Your insight would be greatly appreciated!
Thanks,
Trent
BUT... every pony counts.
I judge things based on the The McRat Constant:
Mods should gain 1rwhp for every 40 dollars spent. This is based on the average price of mods for these cars and their output.
i would like to see a dyno between the ported ones and the aftermarket ones like BBK and so on.
<strong>I haven't seen anyone get more than 3rwhp on a stock engined car yet. Seen about 6 cars dyno with them.
Mods should gain 1rwhp for every 40 dollars spent. This is based on the average price of mods for these cars and their output.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree with McRat...because I gain exactly 3 rwhp and 5 rwtq with the Lingenfelter ported TB on my bolt on car. With a cam or header, or heads and cam I'm sure the ported TB would be worth more...
My LPE ported TB cost $80, or $27 per rwhp so it was worth it to me and McRat would agree I think. LPE may have raised the price to $120 last I heard...
<small>[ May 20, 2002, 10:04 PM: Message edited by: 99 Black Bird T/A ]</small>
<strong>Shaner is currently on a 6-9 month delivery schedule. I wouldn't plan on getting updates either while you wait...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">heheh took me 7 days including shipping but I sent him the one off my car to Port <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thanks fellas!
<strong>This may be a dumb question, but why would the ported throttle body help so much with the same size butterfly valve? I don't see how the throttle body could be a restriction, and even if it was, wouldn't you need to enlarge the butterfly valve to really get more air in there?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well, apply the same principal as supercharging. The butterfly (TB blade) is still the same size but the added air pressure will still give you gobs more power. Same thing with a ported TB only on a smaller level obviously.
I don’t have a ported TB yet. I know I should get one, but I’ve got my TB hole just right for no idle surging with the cam, and I’ve got the blade opening just right to be 90 degrees, so I don’t want to start over on all that. Yes, I’m lazy! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ May 21, 2002, 08:55 AM: Message edited by: RPM WS6 ]</small>
<strong>This may be a dumb question, but why would the ported throttle body help so much with the same size butterfly valve? I don't see how the throttle body could be a restriction, and even if it was, wouldn't you need to enlarge the butterfly valve to really get more air in there?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You are dealing with a series of restrictions.
Each one you remove lessens the total airflow
resistance. I measured (crudely) the pressure
drop through a stock screened MAF and it was
substantial - on the same order as the stock
airbox+filter. I did not have a descreened /
ported MAF to compare. But the measurement
puts the upper end of -airflow- based improvement
on the same order as the lid+K&N mod. There is
also the improvement (or degradation) which
comes from altering the -sensing- of airflow
and affecting mixture. I believe the "screen"
(which in my MAF is really a metal honeycomb
with some thickness to it) does two things:
it is an airflow straightener, and its
restriction biases airflow evenly across the
orifice and sense resistors - at least at
higher flows.
I believe the undesirable mixture deviations
seen by some who try this mod are due to a new
imbalance in airflow across the MAF orifice. The
bends in the inlet tubing appear prone to bias
airflow toward the top of the MAF, to my eye.
The MAF accuracy depends on a certain assumption
of airflow distribution between that sensed by
the resistors, and the rest of the orifice.
The stock unit's characteristics are embodied
in the stock programming.
In my opinion, there is likely a benefit to be
had from making a low restriction airflow
equalizer which would correct this bias -
a very few, wider-spaced vanes forward of the
MAF, or built into the fore end, canted for best
mixture metering result. Trial and error....
These gains would fall right in line with a solid 10hp gain.
Drop Joe an email or call and he can tell you about them.
He added an air lid and gained an additional 14hp I beleive.
Needless to say, the ported TB stayed on his car that day, he bought the ported throttle body then and there from Joe Prince.
<small>[ May 22, 2002, 12:53 PM: Message edited by: The Alchemist ]</small>
<strong>A buddy of mine on this board (Spazeak) tested a JPR ported throttle body on his 100% box stock (right down to the original air box and paper filter) '01 ws6. I beleive he saw a 11hp gain across the board from it. This was done on back to back dynos, the same day, just ten minutes apart.
Needless to say, the ported TB stayed on his car that day, he bought the ported throttle body then and there from Joe Prince.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">While I’m not disputing these gains, this is NOT the norm. Usually stock cars see little to no improvement over stock with ported TBs.
