what gears should i go with?
With that kind of power (or even stock lol), you will shatter the 10 bolt behind a 6-speed car. Leave the 3.42's in untill you can get a 12-bolt. A beefier rear end allows you to run sticky tires, bang gears, dump the clutch, etc. without worring constantly about having your rear end grenade.
My car goes 12.0's on a shitty 1.95 60' cam only, that should cheer you up. I could hit an 11.80 with a 1.75 if i practice more. I make about 400rwhp, and your setup (guessing here) probably makes 430ish depending on how nice the port job is, but it could very well make more (450ish).
Ohh I forgot a put A break line lock in last year so I could smoke my tires a little more but it didnt last long my slave cylinder broke after my second time using it. thats the day the car went into the garage for the mods. So what your saying if I get the wheels and tires now that rear prob wouldnt last long at all if even one launch at higher RPMs... Well the fastest I ever gone is pretty much what the stock 98 TA did. So this summer should be fun.
thanks for all the Help Ill need it LOL
