Are Pulleys worth it?
Old May 23, 2002 | 03:13 PM
ZeeQuick's Avatar
Default Are Pulleys worth it?
I was contemplating purchasing a set of pulleys for my car (crankshaft and alternator). They list for $164 for a harmonically balanced pair. What kind of performance gain am i looking at? Is my money better spent on something else?
Old May 23, 2002 | 03:37 PM
WILWAXU's Avatar
Default Re: Are Pulleys worth it?
I've been very happy with my pulley.
Old May 23, 2002 | 03:39 PM
Angus's Avatar
i know they do make a difference and every bit counts. as to how much i do not know. i have yet to put them on my car
Old May 23, 2002 | 03:54 PM
Supertrapped's Avatar
Speed freak
Most people tend to gain 1mph and 1tenth.
Old May 23, 2002 | 05:16 PM
NastySSoo's Avatar
I only use the crank pulley. Its worth it . Close to 1 tenth and 1 MPH.
Paul
Old May 23, 2002 | 10:33 PM
Jason99T/A's Avatar
I can shift faster than you.
I am very happy with my ASP crank pulley. It is a great mod for the money.
Jason
Old May 24, 2002 | 03:30 AM
Diesel's Avatar
Weren't there some issues with harmonics? I would like <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> to know more about this if anyone can shed some light.
Old May 24, 2002 | 08:13 AM
sweetTA's Avatar
I've heard some complaints, especially with the automatic cars, running both the crank and alternator pullies. Seems the cars don't want to idle <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 24, 2002 | 08:22 AM
Angus's Avatar
my camaro never really dropped in idle rpm and didn't ever die on me. it was a 96Z. also both of my mustangs had the pulley kits on them. it may not give you more power that you will see, but the throttle response you will notice.
Old May 24, 2002 | 10:50 AM
mykdiver's Avatar
I will get mine soon, I have heard they are worth it.
Old May 25, 2002 | 11:50 PM
SS SLP2's Avatar
Not be without (crank only 2 1/2 years ) Thunder has in stock
Old May 26, 2002 | 03:38 PM
Maple Red's Avatar
Dynoed before and after. Worth 9 h.p. on my car. Actual results may vary. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old May 26, 2002 | 08:00 PM
Team ZR-1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ZeeQuick:
<strong>I was contemplating purchasing a set of pulleys for my car (crankshaft and alternator). They list for $164 for a harmonically balanced pair. What kind of performance gain am i looking at? Is my money better spent on something else?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The back side of using 3rd party pulley and undersized ones is
If the pulley is not balanced correctly for the crank you will start getting misfires since pulley is taking crank out of balance and tripping the crank position sensor
I have seen this problem on many LS1 engines.
Smaller pulley will reduce the D/C since the alt is turning less. Over time that could puy out less load then the engine requires.
Old May 26, 2002 | 08:29 PM
spdracer's Avatar
i read on a similar post that there are battery charging issues at idle speed. i had some pullies on a 3rd generation camaro and ruined two altenators(sp) before i took the pullies off. I know that the LS1s are better than the old v8 that i had it is just that i was thinking of getting some of them form my 02 Z28 and did not want to run into the same issues. anyone shed some light on this?
thanks
d
Old May 27, 2002 | 07:46 AM
Ross's Avatar
You will have charging problems.... I don't care what especially with a stereo, or cooling fans running. I didn't 'notice' a gain but others have dyno numbers, so it has to help.
I don't know if this has happened to anybody else, and I know it has never happened before to me, but my belt just about came off last weekend. I popped the hood to show off the engine, there was black rubber dust everywhere, and the belt had about two ribs on the PS pulley. I slipped it back on, just worried if it will happen again.....??
Old May 27, 2002 | 08:55 AM
Gag_Halfront's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ross:
<strong>You will have charging problems.... I don't care what especially with a stereo, or cooling fans running. I didn't 'notice' a gain but others have dyno numbers, so it has to help.
I don't know if this has happened to anybody else, and I know it has never happened before to me, but my belt just about came off last weekend. I popped the hood to show off the engine, there was black rubber dust everywhere, and the belt had about two ribs on the PS pulley. I slipped it back on, just worried if it will happen again.....??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think if I saw that on my car the only place I would drive it would be to the parts store for a new belt!
