FAST 90 TB Bolt torque?
Old Mar 10, 2006 | 03:47 PM
NHRATA01's Avatar
Default FAST 90 TB Bolt torque?
Can someone tell me what you are supposed to torque the TB bolts to on a FAST 90 intake? I've read the instructions over and over, and can't find any reference to the torque #. Closest I can find is a typo that says something about 50 in*lbs, but doesn't say what its for. I tried doing them at 50 in*lbs and created a small crack near one of the upper bolt holes. JB Welded it, tried again today and cracked another bolt hole (and now waiting for the JB weld on that side to cure!). FWIW Tony Mamo put the threaded inserts in the bolt holes when he ported it, so I don't have to use the PITA nuts.
Old Mar 10, 2006 | 03:52 PM
iamsickofitall's Avatar
you cracked it at 50 in-lbs??? that's insane...are you sure you aren't using a ft-lb torque wrench
Old Mar 10, 2006 | 04:23 PM
NHRATA01's Avatar
Oh yah, absolutely! Same wrench I used when torquing down the bolts holding the manifold to the heads. Believe me, I know these things are delicate. I didn't think they were this delicate though!
Old Mar 10, 2006 | 04:42 PM
ROCNDAV's Avatar
50 inch pounds is only like 4 foot pounds. Wow, it shouldn't brake that easy!
Old Mar 10, 2006 | 08:09 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Seriously...thats insane. Something is not right.
Old Mar 10, 2006 | 09:15 PM
joshp14's Avatar
Hand tight or snug should do but damn...50 in/ibs? wow...
Old Mar 11, 2006 | 02:21 PM
BudH's Avatar
I tightened mine to 50 inch lbs. Had it off several times. No problems here!
Old Mar 11, 2006 | 10:07 PM
LS1FIRE's Avatar
I wonder if the makers of FAST has a torque spec for them?
Old Mar 12, 2006 | 09:48 AM
02RedHawk's Avatar
Call them. I believe they have an 800#.
Old Mar 12, 2006 | 11:59 AM
Nick Williams's Avatar
The problem is in the gasket they supply. It is too thick and won't compress far enough to let the TB sit flush with the manifold. If you tighten the bolt too much you just bend the flange on the manifold untill it breaks. I usually make my own gasket using some o-ring material that I have.
Old Mar 12, 2006 | 09:11 PM
NHRATA01's Avatar
Yeah I noticed that gasket is really too big. I didn't know what else to use though. I've got it on at 40 in*lbs right now. Its not flush but seems like it might be sealed. I'll have to see if it leaks when I get it running.
