(POLL) how much oil pressure do you have at idle?
I see this question asked a lot and just figured I'd take a poll and see where most guys oil pressure is at an idle w/the car warmed fully up. I also notice that it seems A4's have slightly lower oil pressure probably due to the fact that they idle a little bit lower than a M6.
LS1Tech Administrator
Received 1,756 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have about 43 or so, but then again my idle was raisd to 850 and I have an ARE ported pump. My stock pump would only hold about 30 when the car was idling at 550, then 35 at 850 idle, so I gained about 8psi over stock with the ARE pump. The pressure also comes up quicker with the ARE, and I’ve got about 15 more psi at WOT then stock...
BTW, my '99 A4 w/44,000+ miles sits at about 40#'s when fully warmed up at an idle (550 rpm's)in park. it will hit 70+ psi at WOT on cool days and about 65 psi on hot days.
Moderator
That's good; my new '02 (still under 2000 miles)
is also a little over 40PSI warmed up, 70 cold
idle. So I guess you don't see too much journal
or pump wear on these motors, if a '99 is still
that tight.
70PSI is probably the relief blow-off pressure.
that tight.
Mine sits right around 40psi with the motor around 180*. When things heat up to around 200* on the hotter days it drops to 35psi or so.
That is with Mobil 1 5 W 30...Im thinking of switching to 10 W 30 next time to see if I get more pressure.
-Doug
98 t/a A4 3.23
<small>[ June 07, 2002, 10:33 AM: Message edited by: 85transamtpi ]</small>
-Doug
98 t/a A4 3.23
Thanks for the replys guys! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
