Horsepower on stock injectors?
Old Jun 13, 2002 | 05:39 AM
346cubes's Avatar
Default Horsepower on stock injectors?
How much power have you put down at the wheels with stock injectors? Facts only please. Calculations and formulas have already been discussed in old posts.
Old Jun 13, 2002 | 09:04 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Horsepower on stock injectors?
Which injectors are you referring to? The '98 and '01+ injectors are bigger than the '99 and '00.
__________________
Old Jun 13, 2002 | 01:23 PM
346cubes's Avatar
Year don't matter. There have been dyno claims of 400+ HP using the 99-00 26# injectors. 1998, 01-02 28# should dyno over that easy. Prove that SVO 30# are not needed until 450+.
Old Jun 13, 2002 | 01:38 PM
Terry Burger's Avatar
435rwhp on 2001 injectors here.
Old Jun 13, 2002 | 02:02 PM
346cubes's Avatar
Thanks Terry, Did you have any lean conditions at high RPM?
Old Jun 14, 2002 | 02:17 PM
NastySSoo's Avatar
417 on 00s. Mine was lean across the board, but richened up a little in the upper rpms. Im getting my tuning adjusted.
Old Jun 14, 2002 | 03:51 PM
Ragtop 99's Avatar
OnyxSS saw an improvement on the dyno from switching from stock 2000 injectors to 30lb SVOs. The dyno was smoother, especially in the higher rpm range (e.g. above 6000 rpm). He was making about 400 HP in an A4.
<small>[ June 14, 2002, 03:53 PM: Message edited by: Ragtop 99 ]</small>
Old Jun 14, 2002 | 11:46 PM
I had 427 RWHP on '98 injectors in my T/A. ATap looked great, but I never had it on a wideband O2 after the changes in heads, intake, etc. It held 12.5:1 a/f ratio up to 7k right after it was built.
__________________
