ported MAF?
Old Mar 14, 2006 | 10:45 PM
stangnightmare's Avatar
Question ported MAF?
porting the MAF; a good thing or a bad thing? seen a few example on some ls1 how to pages. wondering if it's worth doing it?
Old Mar 14, 2006 | 10:46 PM
also some opinions on ported tb's
Old Mar 14, 2006 | 10:52 PM
Justin00SS's Avatar
From what I've been reading (I used the search function) porting the maf is gonna get you nothing for the stock one is good for 500hp.
Porting the tb won't get you much but your throttle response will increase.
Old Mar 18, 2006 | 03:49 PM
WILWAXU's Avatar
With near stock car you can see gains. Once you step to aftermarketing tuning, most tuners can't tune around them.
Old Mar 18, 2006 | 04:08 PM
CRL 01 SS's Avatar
Port your TB. Leave the MAF alone.
Old Mar 18, 2006 | 04:33 PM
I <3 80057's Avatar
What about popping the screen out? Just that and port the TB? May port the TB tomorrow. I JUST did the airbox mod and EGR mod with my Whisper lid and K&N install. To bad the weather sucks and all I can do is crank it up inside the shop,
Blake
Old Mar 18, 2006 | 05:05 PM
CRL 01 SS's Avatar
Blake
Leave the screen in unless you're spraying a dry shot. There is no performance gain from removing the screen, and it will protect the MAF wires from being damaged.
Old Mar 23, 2006 | 02:44 PM
WILWAXU's Avatar
I removed my screen.
Old Mar 23, 2006 | 02:58 PM
jimmyblue's Avatar
Moderator
The screen is a pressure drop equal to that of the stock lid,
by my measurements, therefore holding the same modest
gain. However the screen I expect is also much more non-
linear of a drop, with higher air velocities than those I had
to use. My screen is gone, off a big MAF, and no, it wasn't
necessary or gave any measureable improvement. But it's
done and fine.
Old Mar 23, 2006 | 02:59 PM
Xtnct00WS6's Avatar
I'm with this guy. The MAF is something you really don't want to mess with. You'll probably regret it in the end.
Old Mar 23, 2006 | 03:41 PM
daryl2cb@yahoo.com's Avatar
leave MAF alone, get a ported one (TB) from SDPC if your scared
Old Mar 23, 2006 | 04:41 PM
s346k's Avatar
port the tb if you feel so inclined and leave the maf alone.
when you get headers or something that merits an a/f tune, have the tuner delete the maf entirely. for now leave your screen in as those little wires are VERY sensitive.
sd tuning > maf tuning
