Compression check question
Old Jun 14, 2002 | 10:53 PM
horist's Avatar
Default Compression check question
Ok... I'm going to do a compression check on my car tomorrow (want to make sure every things ok... ). So
1. Pull all spark plugs
2. Pull fuel pump fuse
3. attach compression gauge
4. crank engine over a few times
what should the ideal compression be on each cylinder?
Should they all the the same?
Old Jun 15, 2002 | 04:40 PM
Dipstick's Avatar
Default Re: Compression check question
Don't forget to open the throttle blade all the way. Ususlly they recommend that the reading be within 15#
Old Jun 18, 2002 | 02:20 PM
wizkid's Avatar
Install Director
I can't tell you what the ideal should be (I imagine that would vary some from car to car) but I can say that SlowLS1 did a compression check on his LS1 with GM LS1 Hotcam and all cylinders were between 170 - 175 psi.
Eric
Old Jun 19, 2002 | 09:04 AM
wizkid's Avatar
Install Director
Keep us posted.
Eric
