Hooker Y won't clear....
Find someway to use it that would be more useful for that waste of metal. Maybe try to form it into an aluminum drink can with your rubber mallet or something <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I found I could only get about 1/4" of washers
in there, and still get full thread engagement.
So you might want to go find some longer bolts.
Other thing is, the Y-pipe to I-pipe joint can
give you a lot of bend; floor jack it up to where you have maybe 1" clearance to the driveshaft (or
thereabouts). Then tighten the band clamp in that
position. Do this with the front Y-pipe flange bolts slightly loose, shims between the Y and any
close spots on the frame and gas tank heat shield,
and tighten everything with all this setup in
place, and you should get away with no banging.
Anyone know of such a product?
<strong>The bolts for the brace are pretty short and
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I installed a SLP y-pipe and driveshaft loop on a friends SS and got the longer metric bolts from AutoZone, I think they where 10mm but take one along to make sure.
<strong>I bet there is a driveshalft loop setup that would bolt right in and replace that member. If done right you could have a cross-member that clears the pipe and a proper driveshaft to boot.
Anyone know of such a product?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Got a BMR drive shaft loop. Had to elongate the holes where the loop mounts to the brace and put 2 washers between the brace and body to clear the oryp for my MACS. No big deal took about 1 hour. The factory calls that piece a tunnel brace. Loop replaces it.
Bruce
Anyone know of such a product?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">BMR makes it, and it should fit with a minimal of fuss <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
