SLP Cold Air Upgrade Kit!!
Old Jul 1, 2002 | 08:43 PM
Fast Toys Performance Parts's Avatar
Default SLP Cold Air Upgrade Kit!!
Fast Toys is pleased to announce an upgrade kit for SLP cold air kit owners. This kit will upgrade the SLP kit to be a true ram air kit. The kit includes:
Ram air plate
Removable front rubber seal
Foam seals for airbox
Block off plate
Installation hardware
The kits are introductory priced at 49.99 + shipping.
The kit can be ordered under part # FTSLPCAUP . Kits will be ready to ship early next week.
Thanks!
Old Jul 2, 2002 | 12:12 AM
2000LS1's Avatar
Default Re: SLP Cold Air Upgrade Kit!!
"Removable front rubber seal"
I took this out on my SLP kit to run "cold air" tubes from the front grille of the car to the place up front were the rubber is inserted. Does the seal really "pressurize" the air box?
Old Jul 2, 2002 | 02:17 AM
2000LS1's Avatar
And do you make an enlarged ram air kit for the stealth lid?
Old Jul 2, 2002 | 07:44 AM
Jadeeglide1550's Avatar
I assume you are referring to the sheet metal cold air box that SLP sells, is this correct. If so, will this mod work with the aftermarket lid also? Could you give a description or do you have a picture of the upgrade?
Is it easy to install??? Do you have to remove the grill to install it???
Old Jul 2, 2002 | 10:06 AM
Mark IXZD 150's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000LS1:
<strong>"Removable front rubber seal"
I took this out on my SLP kit to run "cold air" tubes from the front grille of the car to the place up front were the rubber is inserted. Does the seal really "pressurize" the air box?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have the same question. Does the hood scoop need to be blocked off to get the full effect of the underhood version?
Old Jul 2, 2002 | 11:41 AM
WILWAXU's Avatar
He's talking about this...
SLP Cold Air Induction Package
Old Jul 2, 2002 | 11:48 AM
Thanks WilwaxU... that is the one I have. Now ... what does the upgrade do?????
Old Jul 2, 2002 | 01:10 PM
Hi,
The upgrade makes the SLP "cold air kit" into a true ram air kit, very much like the Fast Toys Ram Air Kit. This will give you better performance, throttle response and fuel economy.
Old Jul 2, 2002 | 01:23 PM
Can we order this part now... or do we have to wait until next week...????? Wanted to turn the cold air into a more true ram air.
Old Jul 2, 2002 | 01:29 PM
BLUEBYU's Avatar
Well looky here....I requested this mod about a month ago.. I guess Phillip and FT thought it was a good idea too. Grassy ***!!!! I should get some kind of freebe though... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Doesn't hurt to ask? I will be adding this mod to my CAI when available. BTW, yes the blocking of the air box does make a big difference in the performance of the ram air...A BIG DIFFERENCE! I used the piece sent with the SLP kit though so I don't need the rubber seal insert that comes with this upgrade. What is the difference between...Removable front rubber seal and Foam seals for airbox? I believe the rubber seal is the piece I was just referring to and are the foam seals the same pieces I have now that seal the gap between the lid and the top of the CAI?
2000LS1: Just run the ducting under the washer fluid res. through two holes you need to dremel in the bottom corners of the deflector shield. Discharge the ducting into the CAI intake and hold in place by wrapping the ends of the ducts with 2 sided carpet tape. BTW, I added a piece of panty hose to each duct discharge to help filter out bugs, etc. and secured with rubber bands under the tape.
Hope this helps.
Thanks for listening FastToys!!!!!!!!!!
Old Jul 2, 2002 | 04:27 PM
RoRsChAcH's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fast Toys Performance Parts:
<strong>Fast Toys is pleased to announce an upgrade kit for SLP cold air kit owners. This kit will upgrade the SLP kit to be a true ram air kit. The kit includes:
Ram air plate
Block off plate
Thanks!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> FINALLY!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Will be calling in the next week or two to order one.
