Radiator Fans ??????
Old Jul 16, 2002 | 09:15 AM
Jack Daniels's Avatar
Default Radiator Fans ??????
Can somebody check for me today and see if their radiator fans come on high when the a/c is turned on max? I'm having a/c trouble and my fans are not going on high. I think they are supposed to anytime the a/c is put on the max setting and this may be my problem. My shop manual wasn't much help on this and I'm thinking I may have a bad relay.
Thanks!
Old Jul 16, 2002 | 10:20 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: Radiator Fans ??????
No high speed fans when AC on, unless ECT gets to high speed turn on temp.(confirmed this with my manual fan switch).
I do believe the fans run on low speed w/AC on.
Old Jul 16, 2002 | 10:27 AM
Ok, thanks for the help. Guess I have a typical low charge condition. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Everything else seems to be normal. Compressor, blower, etc. working fine. I swear my car used to put the radiator fans on high whenever I went to max a/c. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Guess I'm geezing.
Old Jul 16, 2002 | 02:22 PM
TA_2001's Avatar
2001 I belive I have high speed fans running,
because the car will actually run cooler than
if the AC is off and I have on manual low speed
fans.. according to digital temp gauge.
Also the noise seems way higher with ac on..
Ill check for sure in a bit..
Old Jul 16, 2002 | 02:29 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TA_2001:
<strong>2001 I belive I have high speed fans running,
Ill check for sure in a bit..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's what I thought. Thanks for checking.
Old Jul 16, 2002 | 02:32 PM
gwj's Avatar
gwj
After the initial request I went outside and fired mine up (was pretty warmed up from some earlier tweaking). Hood was up.
Turned AC on normal.
Flipped manual switch on high, high fans then kicked on.
(You can hear the difference) <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Turned AC on MAX.
Unless my Y2K works different than other years...
Old Jul 16, 2002 | 02:39 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gwj:
<strong>After the initial request I went outside and fired mine up (was pretty warmed up from some earlier tweaking). Hood was up.
Turned AC on MAX.
Unless my Y2K works different than other years...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So you're confirming that the high speed fans don't run under normal conditions when the a/c is turned on?
The only reason I'm doubting is because I distinctly remember my fans going to high speed whenever I turned on the a/c. I might be crazy or my '98 may be different than your '00.
Either way, thanks again. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'd sure like to hear from a few others on this.
Old Jul 17, 2002 | 08:27 AM
TTT. Could anybody else please look at their car for me? I'd like to get a few others, especially a '98. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 17, 2002 | 11:00 AM
gwj's Avatar
gwj
JD, I know mine don't run on high speed when the AC is on. Besides my quick check, I know that very often when I'm sitting in a bank line, for example, and hear my fans kick on/off high speed from extended idling. And here in Florida, my AC is on probably 10 months out of the year.
But like I say, '98s may be different.
TTT for ya.
Edit: thinking back about it, one of the reasons I like the manual switch is so I can keep fans on high in stop/start traffic-seems to keep AC cooler.
<small>[ July 17, 2002, 11:02 AM: Message edited by: gwj ]</small>
Old Jul 17, 2002 | 11:04 AM
Thanks. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Every little bit of info helps. I was hoping to get the answer in my shop manuals, but it's not there. I messed around with the car last nite and couldn't get the high speed fans to come on at all. It was 90+ yesterday here.
