why is coolat pouring from the driver side head???
i just finished putting the heads on and when i started adding coolant , i noticed coolant pouring from betwen the hesd and block on the driver side.
i have the cometic gasket on there , and i know it's reusable , so that's why i reused it. i also checked the head blots and they seem very tight.
what is wrong here??
the heads and gasket had about 1000 miles on them when i took them off. nothing like that before.
uuhhhh........ <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
guess it's off with the heads tonight.
but lets say i had them on right, why would the head leak like that??
<small>[ July 30, 2002, 09:17 PM: Message edited by: 1dirtyZ ]</small>
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Can you explain what you mean by " just finished putting the heads on ", are these new heads or did you have your's reworked? I'm not sure I'd reuse head gaskets no matter what kind they are, best of luck.
Al
Al
If it was pouring out and you didn't have the car running you have major problems. Sounds like you hydrolocked the bolts and the head isn't compressing gasket.
jp9 , i think that's the case, cause it's seeping badly , and i still did't start the engine yet!
dark, the heads were reworked recently, i took them off cause the some of the lifters were bad.
the heads and gasket had less than 1000 miles on them. and yes the gaskets are reusable ( someone reused them about 15 times!!)
Location: Richmond, VA Where fast cars, well......are hard to come by.
Read this just to eliminate that as the problem.
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=004358
<small>[ July 31, 2002, 12:40 AM: Message edited by: AzzHauler ]</small>
well i'm using cometic gaskets , so that eliminates that theory.
i think i found out what it is though.
i just finished removing the head that was leaking and noticed something wrong with the gasket. the cometic gaskets have a 2 peice oringed layer between the top and bottom layers.the 2 peices are not supposed to overlap which saeems to be the case on my car.
i'll see how it comes out tommorow since i have to buy some new head bolts.
i'm just hoping that this was the cause.
Before you put the heads back on did you suck out ALL of the water from the bolt holes?????? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> If not you have water in them and torqued the bolts but they did not pull on the heads because the water keeping the bolt from going in farther.
<img src="http://groups.msn.com/_Secure/0NABlAPgQh6WAQyusDSi8K7Zd2yOIOD2zKtfvYU6zLpaQcou6f ALMmsPtJ1xm1mRCSPj7qM92vaISjW!X29hXRw/Pict00250.JPG" alt=" - " />
Notice what I used on the end of the hose to get down to the bottom of the bolt hole.
