Belt Tensioner cause Knock Retard?
I've had around 9 degrees of knock when I've been A-Tapping and noticed that my belt tends to slip nearly off all the time after each run. I never get knock unless I'm at WOT. The tensioner is comming apart and is wobbling. Could that cause some of the knock you think possibly? <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Re: Belt Tensioner cause Knock Retard?
So with the new style is there anything I have to change? Also could that be the cause of the knock?
katech sells a tensioner that they use on their c5r vette. they say that they had to use it cause of the harmonics they encountered which led the belt to vibrate off at around 4k rpm.
check their website out.
There is a GM tech service bulletin conerning the belt squeaking - this may also cause your problem. Will provide info if interested. I think I'm going to do mine.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong>katech sells a tensioner that they use on their c5r vette. they say that they had to use it cause of the harmonics they encountered which led the belt to vibrate off at around 4k rpm.
check their website out.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">!! That's just the rpm where I've always gotten KR - never would have thought of the belt as possible cause. Guess there's no way to tell without changing it tho... ?
Has anyone verified that this is the cause? I have problems with my belt coming off on WOT runs too. Now it's squealing, but I'm pretty sure it's the idler pully ( spraying WD-40 shuts it up for about a minute on that pully ). Plus I seem to get knock even if I run 100 octane.
- Dug
- Dug
