AIR & EGR removal
Old Jun 9, 2007 | 09:43 PM
  #81
ONEBADASSWS6's Avatar
Originally Posted by ChocoTaco369
just to let you guys know:
it's perfectly understandable that removing EGR would hurt your gas mileage. EGR recirculates exhaust gases back into your intake. this would, in theory, raise intake air temperatures. you have to understand that our motors like to be hot. i don't know about you guys, but i get 18 mpg in the winter and 22 mpg in the summer. i don't drive any differently. engines just run more efficiently HOT. when you're injecting hotter air into your car, while you'll in theory lose power, the engine will run more efficiently and use less gas.
yes, EGR can and should lower your gas mileage, although not by a whole lot. removing AIR shouldn't hurt your mileage at all unless you cause an exhaust leak in the process.
Not having EGR has little to no effect on fuel economy. Otherwise all 01-02 F-Bodies would have lower fuel economy ratings than 98-00 models, and I've never heard of any real differences. Not only that, but once the motor is warmed up, the last thing you want is hot exhaust air coming into the intake manifold. You want a cold air charge, cooler air is more dense than warmer air. Hence cold air induction setups, intercoolers, ect. A denser air charge will make more power and be more efficient than a warmer air charge.
I think you are confusing intake air temps with engine temps. They are not the same thing. You want the engine to be warm (180-210 degrees) and the air charge to be cool, that gives you the best efficiency and power.
FWIW, while we're on the subject of gas mileage, swapping to a 160* thermostat will also hurt your gas mileage. our motors were designed to run hot. the cooler we run them, the less efficiently they burn fuel which will result in poorer fuel economy.
my $0.02.
It will only hurt your mileage during the time the car is warming up, since it will take more time to get from 160 degrees to operating temp with coolant flowing through the engine. However, once the car is warmed up, it has no effect on anything, because the engine temps are controlled by the cooling fans, not the thermostat.
Old Jul 21, 2007 | 02:40 PM
  #82
OMGWTFBODY's Avatar
my $0.02.
This is true. But if I recall, aluminum is also more susceptible to heat damage: IE warping, than iron. I will gladly sacrifice 1-2 MPG know that I will have a little more time/temp difference should I start to run hot.
Old May 17, 2013 | 12:59 PM
  #83
Flubyux2's Avatar
Removing the egr from a car originally equipped, and not retuning it, usually hurts the fuel economy. The exhaust is an inert gas that dilute the fresh air charge. Since there's supposed to be less fresh air, the ecu uses less fuel. Having the exhaust recirc with the fresh charge doesn't affect the afr, the stoich is achieved. But if you eliminate the inert gas, it changes the mixture. More fresh air is drawn in in the absence of the exhaust. This causes a lean condition and is picked up by the front o2's. The ecu sees this on the long term o2 trims and then compensates by adjusting the fuel trims. This adds more fuel... And then you mpg would suffer at this point.
A car designed to run Without egr systems uses different cam timing events to utilize overlap to create exhaust reversion which will dilute the incoming air charge similar to how egr would when being routed through the intake.
I want to delete these systems but I really hesitant because I take road trips and getting less than 25mpg on the hwy is unacceptable. So I'm thinking I won't be able to delete the egr.
As far as the Air system, do you guys with catless exhausts notice rich, dirty or raw fuel smells on cold starts? I've built emissions-free cars all my life but I'm honestly gettin tired of smelling cars that smell like my law mower. The fact that most gas stations down here are using fuel refined from sour crude makes it that much worse: sour exhaust on a catless car that runs rich will get old quickly for me.
Old May 19, 2013 | 06:43 PM
  #84
7beast's Avatar
good info here, my intake already has the block off plate and will be ordering race headers before i drop my motor in
Old Jan 21, 2015 | 04:47 PM
  #85
trey0153's Avatar
I know this is old but just as an update u can get an grommet that is put in holes for electrical panels to close hole and looks way better then the freeze plug
Old Sep 2, 2016 | 06:44 PM
  #86
T2TA's Avatar
Just finished this today. I know this and several other threads are a bit dated - but it's pretty simple. .... For anyone still interested ... Lol
Just read through this thread and these (with links in posts). https://ls1tech.com/forums/generatio...r-removal.html and. https://ls1tech.com/forums/generatio...questions.html
Pump removal is easy. People just seem to get confused on the solenoid and air valve (saucer looking thing). Last couple of links have decent explanations and faqs.
And the line to cap is the one coming from the back of the intake manifold into the solenoid. The other lines run the "vacuum" from the solenoid to the valve. So all that matters, once all is removed, is capping the vacuum source line.
This helps ... The pic is from SSGunny
1. Mount for bracket
2. Vacuum line elbow
3. Vacuum check valve
4. AIR shutoff valve
5. AIR vacuum solenoid
Old Sep 21, 2016 | 12:44 PM
  #87
Rick01SS's Avatar
You cap the line at the back of the intake and everything else is removed?
Do you pull all of it off the back of the intake and install a freeze plug, or is that for !EGR? Or just cap the line?
Thanks!
By Brett Foote | 2026-06-04 05:00:17
