EXTERNAL Fuel Pump Recommendations?
Old Aug 15, 2002 | 04:57 PM
Guest
Guest
Posts: n/a
Default EXTERNAL Fuel Pump Recommendations?
I have an applicaton where I'm installing an LS-1 in a vehicle that is already set up for an external fuel pump. It has a baffled tank, supply and return lines - so it also is designed to run with a fuel pressure regulator.
Can anyone give me recommendations for an LS-1 compatible external pump that is designed to be used externally to the tank with an FPR?
Thanks in advance.
Old Aug 16, 2002 | 07:53 AM
Guest
Guest
Posts: n/a
Default Re: EXTERNAL Fuel Pump Recommendations?
Just moving this back to the top. Any inputs please??
Old Aug 16, 2002 | 08:09 AM
2000 Camaro SS's Avatar
You know I think most in-line fuel pumps will work. I just installed a Bosch fuel pump, originally it would be installed in a tank but it is mounted outside of the take. I did however install a switch to turn it on only when I shoot nitrous. There are many pumps you can use all are around $150 to $250 but if you look in the parts classified section you might find one cheaper. Unfortunately fuel pump questions for the most part go un answered for some reason. I posted a few and got little responses, I resorted to going to other sights to get my information. Here is a link to what I posted....
https://ls1tech.com/ubb/ultimatebb.p...;f=24;t=002763
Old Aug 16, 2002 | 08:48 AM
Reckless's Avatar
Super Moderator
I am using the Aeromotive pump (model 1000) and a Paxton regulator. Not too loud either. I also use the Aeromotive electronic pump controller to run the pump at a slower speed for street driving.
I used a Weldon pump for a long time, but they are insanely loud!
Old Aug 16, 2002 | 11:47 AM
Guest
Guest
Posts: n/a
Thanks guys. This will really help. Pump and pressure regulator suggestions. Both are great.
Old Aug 16, 2002 | 10:02 PM
GeorgeC's Avatar
I run the Aeromotive A1000 pump and Aeromotive regulator also. Works great for me, and you'll probably never outgrow that fuel pump <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 17, 2002 | 11:07 PM
Postal's Avatar
Reckless, do you mind explaing your expierences with the pump controller?
Old Sep 3, 2002 | 01:54 PM
Guest
Guest
Posts: n/a
Just bringing this back to the top. Any additional suggestions?
Old Sep 4, 2002 | 01:17 AM
JimmyKash's Avatar
bosch 420lt/hr or 110gph pump
speed inc sells them
never worry again
Old Sep 4, 2002 | 01:59 AM
NataSS Inc's Avatar
I think it all depends on how crazy you want to get. All the inline stuff works pretty good for most applications. I am going to be trying out the new Barry Grant "King Sumo" here in the very near future.
Old Sep 4, 2002 | 08:24 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I am very happy with my MagnaFlow 300 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 4, 2002 | 08:31 AM
Reckless's Avatar
Super Moderator
The pump controller works great. Now that I am back to running NA, I always run the pump at half speed. Don't really have the need to run at full speed, unless I put some N2O back on there.
It's easy to wire up and works well. Will be helping a friend install one on his ATI car very soon.
Todd
