Two cables on throttle body?
Old Apr 5, 2006 | 06:54 AM
02SS:ZEUS's Avatar
Default Two cables on throttle body?
What is the difference between a trottle body with two throttle cables, and a throttle body with one throttle cable?
Old Apr 5, 2006 | 07:52 AM
thunderstruck's Avatar
two cables is cruise, one cable is no cruise i believe
Old Apr 5, 2006 | 07:57 AM
theinstag8r's Avatar
two cables w/cruse only .......one cable has cruise but also has traction control and they only run one cable to the tb from the tc unit, from what i saw anyway
Old Apr 5, 2006 | 09:27 AM
jmm98LS1's Avatar
Yep, if you have traction control you'll only have the throttle cable at the tb since cruise is integrated into the tcs module. If you don't have traction control you'll have a throttle cable and a cruise cable at the tb.
Old Apr 5, 2006 | 03:28 PM
daryl2cb@yahoo.com's Avatar
correct one wire with traction control
Old Apr 6, 2006 | 12:36 PM
WS6RED2002TA's Avatar
I have one cable on my throttle body, but how come I don't have a switch like in my buddys car to turn of TCS. Does this mean I dont have traction control, or I just can't turn it off and on.
Old Apr 6, 2006 | 01:45 PM
jmm98LS1's Avatar
Ok, look at this picture. See the black "thingy" right above the battery with the 3 cables running to it? That's the traction control module. If you have one of these, you have traction control. If you don't have the module, you don't have traction control. (Thanks for the pic 2SSlow!)
Old Apr 6, 2006 | 02:45 PM
Right now im at work so the pics are blocked I will check them out when i get home.
Old Apr 6, 2006 | 03:01 PM
lt1formula2000's Avatar
a prev. owner could have for some reason removed the cruise cable. or maybe you had TCS and it was removed and the owner swapped to the throttle cable for non TCS but didn't get the cable or box/module for cruise without TCS. not sure what the RPO code for TCS is. that would be the easy way to check what you orginally had.
