how do I remove the EGR tube?
Old Aug 26, 2002 | 12:07 AM
SSpray's Avatar
Default how do I remove the EGR tube?
I want to remove the tube that goes from the intake to the EGR cansiter/pump thing.
how do I remove the hose from the canister thing?
-thanks
Old Aug 26, 2002 | 12:17 AM
FAST LS1's Avatar
Default Re: how do I remove the EGR tube?
The metal tube is flared at the pump housing. I think you pretty much have to take off the whole assembly, meaning the tube that goes to the intake, pump, bracket, and tube that goes to the exhaust header.
There's a write up on how to take it off on http://www.installuniversity.com/ under Install Documents, then !EGR Free Modification
It's not hard, just watch the little rubber o-ring when you take the tubing out of the intake.
Old Aug 26, 2002 | 12:21 AM
SSpray's Avatar
i want to leave it looked to the header (exhost manifold) i just want to remove the hose that runs from the intake to the pump. I already have it removed from the intake, now I need to bust it off of the EGR pump. how do I do that neatly, so I can re atatch something in its place?
thanks!
Old Aug 26, 2002 | 12:28 AM
FAST LS1's Avatar
Well since it's flared at the pump mounting bracket you need to take the pump off. Then I guess if you don't want the tube there at all you could cut the tube just below the bracket, and slide the cut part out the top of the bracket?
Old Aug 26, 2002 | 01:49 AM
buschman's Avatar
You want to keep the canister but remove the tube from the intake... Why? Personally I think you are making things more difficult for yourself. If you ant to simply remove the tube then there is one bolt that holds it in the intake manifold. You can remove it and in it's place go to Pep Boys and buy a $3 1 3/8" freeze expansion plug to fit in the whole.
However you are still going to throw a code and EGR will be completely non functional. So you might as well remove the whole thing and svae yourself some weight. In this case make or buy a block off plate(I've seen guys selling good ones at resonable prices) and get the freeze expansion plug. You'll still throw a code unless you have EDIT or something like that to remove the code.
Good luck,
Mike
Old Aug 26, 2002 | 10:26 AM
Steve1969LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by buschman:
<strong>You want to keep the canister but remove the tube from the intake... Why? Personally I think you are making things more difficult for yourself. If you ant to simply remove the tube then there is one bolt that holds it in the intake manifold. You can remove it and in it's place go to Pep Boys and buy a $3 1 3/8" freeze expansion plug to fit in the whole.
Good luck,
Mike</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What he said.. I just removed my EGR system.. blocked off the header tube ($10) and used a 1 3/8 expansion plug for the intake.. LS1 edit in a few days should remove the SES light.. the engine area looks SO much better now.. cheaper than buying a 01 or 02 car <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 27, 2002 | 12:07 AM
SSpray's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSpray:
<strong>i want to leave it hooked to the header (exhost manifold) i just want to remove the hose that runs from the intake to the pump. I already have it removed from the intake, now I need to bust it off of the EGR pump. how do I do that neatly, so I can re atatch something in its place?
thanks!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">guys guys guys! please read what I wrote!
Old Aug 27, 2002 | 12:10 AM
SSpray's Avatar
I just want to know how to remove the tube (that runs to the intake) from the EGR canister/pump thing.
I have my reasons for this.
-thanks
